strange clicking inside car when moving?
Car: 1984 Trans Am
Engine: 305 cui
So yet again I put my 1984 Trans Am here for the reason this time, of a strange clicking coming from the center of the car, I rolled down the windows to see if I can hear it outside too, but I hear nothing its weird, only when the car is driving or if the car if revving really high (2000 rpm) do i hear it.
i took a video while driving to show what i mean
thanks guys!
thanks guys!
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: strange clicking inside car when moving?
Look under the car to see if you see anything weird on/around the driveshaft.
Car: 1984 Trans Am
Engine: 305 cui
what should i look for?
as an added note, i remember that the transmission mount had gone and would cause the tranny to jump when shifting first gear to second, literally mad the center consle flex to a side. i fixed the mount but i remember seeing some grooves above the drive train on the body, it really concerned me. could my problem be caused by that kind of thing
thanks again
thanks again
Car: 1984 Trans Am
Engine: 305 cui
So today while driving my car, I noticed that the noise still stayed when the war was at idle and comes and goes, I'm hoping its nothing major
Thanks again guys
Thanks again guys
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
Check out your U-Joints..sounds like it could be the one that comes right off the end of the transmission. a bad U-joint can cause noises such as these (i actually watched your video). Also a possibility is some bad bearings. I have this weird clicking noise coming from my 89 IROC, its not as loud as yours is, but sounds just about the same, turns out i need some new pinion bearings and carrier bearings in my differential housing.
just in case you don't know, to check for a bad U-Joint. jack your car up and put it on stands. crawl underneath and find your driveshaft. once you find it, get a firm grip on it and try to turn it either direction...if there is any play in it, you have a bad U-Joint and definitely needs to be replaced.
hope this helps!
hope this helps!
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Stop driving it until you figure out what's going on. It's not the U joints if it still makes the noise while standing still. Must be coming from the flexplate/torque converter area.
Car: 1984 Trans Am
Engine: 305 cui
i checked the U-joints on the car, that wasn't it. so now i'm going ahead and seeing about that flex plate. recently it has gotten better and i rarely hear it now, but all the same i want it gone since it might be something concerning
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
When I put the new motor in my car, I had it running and drove it for about, 50 miles, when I started getting a pinging/clicking noise coming from the center of the car area even at idle. Pulled the inspection plate on the tranny and found my flywheel/flexplate bolts all coming loose which caused it to wobble in place catching the bolts on things as they swung by.
Linson
Aug 21, 2015 02:12 PM
AkDrifted
Aug 17, 2015 07:45 PM
db057
Aug 11, 2015 10:11 PM
