Best use of $1000
Old Jan 22, 2013 | 11:03 PM
RWO3's Avatar
Car: '84 Camaro Sport Coupe
Engine: 355
Axle/Gears: 3.08
Best use of $1000
I have the opportunity of rebuilding my engine as part of an engine rebuilding class in college. I'd love to use this opportunity to get some performance out of my car. I'm wondering what you guys would suggest. My engine is a stock '84 LG4 305. My budget is 750-1000$. I've been thinking about swapping blocks for a 350. There happens to be one I can buy from the garage. What parts can I carry over from my old 305 into the 350 block? Will I be best off getting new heads? I'm thinking something on the lines of a better cam, carb, and some sort of change to the exhaust.
Thanks!
Old Jan 22, 2013 | 11:08 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Best use of $1000
I would go to the Junkyard and pick up a Vortec 350... get a mild cam and rebuild it...
Old Jan 23, 2013 | 06:15 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
^THIS^
Old Jan 23, 2013 | 08:14 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
You can get just as much wrench time and wiring time working on refurbing smaller things than if you just do the old pull smaller motor and stick in bigger motor.
If you blow your budget on the bigger motor, you'll just have a car with a bigger motor, and all those old parts still to deal with. While its true that its the motor that gets you down the road fast, its the small stuff that will put you off the road even faster.
If all your brake systems, and electrical systems are already perfect, then disregard my observation.
But I doubt you can go over that old car with even a voltmeter and not find plenty of stuff to work on.
Old Jan 23, 2013 | 09:55 AM
nowerelsetoroam's Avatar
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
I did what your doing for 1500.
Took out the LG4 and used the flexplate, starter, waterpump and fuel
Pump on a 4bolt 350. The parts on my 305 were still good though.
Sold the LG4 for 200. I used that towards building the 350.
I put vortec.heads on it with the intake manifold it needs. Put a mild cam on it.
Some new hypereutectic pistons I got for dirt cheap
Uses the rest for.some short headers and y pipe and that's it.
It runs a lot better then the 305 but of course my weak.point now is
The transmission.
Old Jan 29, 2013 | 10:52 PM
RWO3's Avatar
Engine: 355
Axle/Gears: 3.08
Thanks for the imput. After seeing the same suggestion other places aswell, I indeed decided to go with a Vortec 350. The shop said I can buy one from them to rebuild.
My budget turns out to be a little higher then I first thought so I'm still thinking about a better manifold, cam, and some sort of exhaust upgrade. I'd love to get alteast 300hp out of the set up.
Old Jan 30, 2013 | 12:28 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I would do a cam, and some port matching... You can always upgrade the intake later fairly easily!
Old Feb 6, 2013 | 02:18 AM
wbstearns's Avatar
Car: 01 s10 blazer and 89 bird
Engine: 383 with mystery cam - maybe
Transmission: t56 hopefully
Axle/Gears: 373 geared posi from 2002 z28
stick with the vortech and put the extra you came up with into putting that power to the ground with a set of wheels and tires as they are the only thing that actually touches the road no point in all that power and it just costing you $$ in tire smoke
Old Feb 6, 2013 | 08:29 AM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Clean up the Vortec heads and find a complete camkit with springs, a 224 or bigger cam. check P to V clearance, airgap intake.. Your car has a Q Jet carb now?
Old Feb 6, 2013 | 08:36 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Best use of 1k ? I'd say put it in the bank and add to it until you get around 5k.
Then you can do more and have some fun.
Old Feb 6, 2013 | 11:52 AM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
Save it for a rainy day
db057
Jan 10, 2020 08:55 PM
PurelyPMD
May 5, 2016 04:57 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
AussieZ28
Sep 30, 2015 03:36 PM
