car turns over until the battery dies
Old May 27, 2013 | 03:34 PM
likwidmetaldeth's Avatar
Car: 87 firebird
Engine: lg4
any tips? i just resealed the intake manifold (used permatex red gasket maker instead of o2 sensor silicone this time) im sure i wired something up wrong but i cant figure out what. When i turn the key the engine cranks and doesnt stop cranking until it runs out of battery. HELP??
Old May 27, 2013 | 04:12 PM
Car: 87 firebird
Engine: lg4
Re: car turns over until the battery dies
it is also eating my batteries
Old May 27, 2013 | 04:28 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
It was starting before you did intake? , if so , just have to go over everything you did. Distributor hooked back up? coil? fuel lines? If so, next step is to check for fuel and spark.
Old May 27, 2013 | 04:31 PM
Car: 87 firebird
Engine: lg4
started great before i took everything apart. it seems like an ignition problem but i only messed with three connectors that were ignition related. as far as i can tell everything is hooked up correctly. the spark and fuel wouldnt explain why it didnt stop cranking tho... tried to check my relays but our multimeter doest work
Old May 27, 2013 | 04:32 PM
Guest
Guest
Posts: n/a
Dang dude that would freak me out. Just to hear it screeching like its going to start non-stop. Interesting I've never heard of this
Old May 27, 2013 | 06:35 PM
Get another.
Most likely, you stabbed the dist back in, in the wrong spot.
See my signature for help.
Old May 28, 2013 | 12:25 AM
Car: 87 firebird
Engine: lg4
i marked the rotor and housing so i wouldnt mess up the timing. is that what you were talking about? im new to this forum
Old May 28, 2013 | 08:34 AM
danclemts's Avatar
Yes, getting distributor back in wrong will make it not start. It's easy to get it off though, the rotor turns 30 degrees when pulling the dist, and maybe the crank moved? Might be best to static time it to eliminate that possibility
If you are getting a spark at plugs, and fuel . thats a strong possibility
Old May 28, 2013 | 05:03 PM
Car: 87 firebird
Engine: lg4
how would i put the dist in correctly?
Old May 28, 2013 | 05:29 PM
Car: 87 firebird
Engine: lg4
what do you mean the rotor turns 30 degrees? it went in easily and lined up with my marks. also, could this cause the cranking problem? im more concerned with that than the not starting
Old May 28, 2013 | 06:05 PM
OrangeBird's Avatar
Car: 1989 Firebird
I don't think you've quite framed the cranking question in a way that's understandable , and that's why no one has mentioned it . Are we to believe that when you turn the key to the start position , the starter begins to turn the engine's crankshaft , and then when the engine does not start and you let go of the key to stop attempting to start it , that the engine just keeps on cranking , even though you aren't holding the key to the start position ????
If this is true , maybe your starter's solenoid is sticking ???
Old May 28, 2013 | 10:37 PM
Car: 87 firebird
Engine: lg4
yeah when i turn the key the engine cranks, and it continues to crank, even when i turn off the key. i had my starter tested today and it failed, so i think youre right it was the solenoid. (btw can you get the starter off without removing the exhaust??? i couldnt) may need ANOTHER new battery tho
Old May 28, 2013 | 11:01 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
For starter removal check this out.
https://www.thirdgen.org/forums/tech...rter-help.html
Steven 86IROC-Z
May 24, 2026 04:52 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 9, 2015 05:27 PM
