engine stalls on left turns
Old Sep 20, 2013 | 06:10 PM
D&S 85 IROC's Avatar
Car: 85 IROCZ
Engine: 350 TPI with a fast EZ efi
Transmission: t-5 conversion
Axle/Gears: 3;42
Hey guys check this out, it seems like if I go into a hard left turn the car stalls, shift to neutral starts right up. Any ideas!!!!!!!! to a cause.
Old Sep 20, 2013 | 08:46 PM
maxjivi05's Avatar
Re: engine stalls on left turns
Are you low on gas, fuel pressure fine??
Old Sep 20, 2013 | 08:52 PM
Car: 85 IROCZ
Axle/Gears: 3;42
full tank, i'm kinda thinking the fuel pump is on it's way out to lunch
Old Sep 20, 2013 | 09:18 PM
maxjivi05's Avatar
Could be fuel the pump is going bad, or could be a short in the power to the fuel pump. Since it don't happen on right hand turns I'd look at wiring diagram for the fuel pump and check all the lines out make sure the voltages are correct and the fuel pumps ground is good, but that seems like the #1 thing to check.
Old Oct 2, 2013 | 03:28 PM
dusty42701's Avatar
Also check your power steering fluid. I've seen something similar caused by a pump running dry.
Old Oct 2, 2013 | 03:36 PM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Do you hear any grinding on left turns? or any smoke out of the tailpipes?
Old Oct 2, 2013 | 04:07 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Check to see if your tire is rubbing in the wheel well.
Old Oct 2, 2013 | 05:55 PM
FILL the gas tank.
Not, "put some gas in it"; FILL it.
If it goes away, then keep more gas in the tank.
Old Oct 2, 2013 | 06:34 PM
z28v8's Avatar
Car: 1987 IROC-Z
make sure the glove box is securely latched.
Old Oct 2, 2013 | 07:18 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
OP says tank is full.
Problem could be battery connection. If a connection is corroded, turning one way could cause enough G-force to make the battery lose contact with the cable.
Old Oct 2, 2013 | 08:19 PM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Transmission: auto/stock
Axle/Gears: stock
huh?? after the car is running isn't it like running off the alternator the whole time? I have taken the terminals off after the car was running and it didn't shut off.. is this some safety thing on new cars?
Old Oct 2, 2013 | 08:32 PM
z28v8's Avatar
Car: 1987 IROC-Z
ok.... after reading through a few silly answers I'm going to go out on a limb and guess that you have a carb'ed engine. If so, the culprit is likely a sinking float.
Otherwise, remember that 2 wrongs don't make a right but that 3 rights make a left
Old Oct 2, 2013 | 09:05 PM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: stock
good call!!! I once had a amc hornet that had the exact same issue.. not enough fuel and I had to replace the float.. holy **** this brings back memories.. I miss that old pile..
Old Oct 2, 2013 | 09:59 PM
Car: 85 IROCZ
Axle/Gears: 3;42
it has a TPI motor.
Old Oct 3, 2013 | 06:55 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Loose grounds on the back of drivers side head, where fuel pump relay grounds. Mine was only finger tight!
Old Oct 4, 2013 | 07:24 PM
Car: 85 IROCZ
Axle/Gears: 3;42
I got to thank everyone for all there ideas, and suggestions, I found the problem. It was a loose coil wire on the coil it was just sitting there I found it while I was checking the oil pressure switch. Thanks again.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Fronzizzle
Aug 9, 2015 01:15 PM
