vortec heads and mother thumper cam
Old Mar 19, 2014 | 10:24 PM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
http://www.alexsparts.com/valve-spri...d-flat-tappet/ found these springs and thought they would be ok but just looking over cam card and dont think they will work. Dont know how to post pics so all I can do it post links. This is the cam I got http://www.summitracing.com/parts/cc...01-8/overview/ anybody have vortec heads and running this cam? I already got my vortec heads back from machine shop. Milld and machined for PC seals machined for guide plates and screw in rocker studs 3 angle valve job and new valve guides. I dont know the spec of installed height right now but I know I got alot more clearance with the PC seals
Old Mar 20, 2014 | 06:24 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: vortec heads and mother thumper cam
You should run this kit and shim to 130 lbs on the seat:
http://www.alexsparts.com/valve-spri...rf-hyd-roller/
Old Mar 20, 2014 | 09:29 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
If you can return that cam and get something from the xtreem energy line
Old Mar 20, 2014 | 09:41 AM
Car: 92 camaro RS
Cant return it its already in motor. But thats the same springs as I posted 86bird
Old Mar 20, 2014 | 09:48 AM
midias's Avatar
I don't see how it will give you any issues with the heads, it was more of a performance issue. They should play just fine together.
Old Mar 20, 2014 | 11:49 AM
86LG4Bird's Avatar
... But thats the same springs as I posted 86bird
Look closely. You want the VSK600VFR kit, not the VSK600VFT that you linked.
It's looks like their "webmaster" has been in there editing things. The write-up under ...VFR used to say 130 lbs seat; now it states you need to shim to get to that.
Old Mar 20, 2014 | 12:07 PM
Car: 92 camaro RS
Where do you see that part number at? I entered it in the search and came up with nothing and I go back to the srping I posted and cant find a part number
Old Mar 20, 2014 | 12:20 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
It is right there under the price. SKU
Old Mar 20, 2014 | 01:04 PM
Car: 92 camaro RS
Ok I got it. I see the part number now. But instead of VFT like you said I need. Did you mean VHR?
Car: 92 camaro RS
I didnt see that I was looking at the flat tappet springs but yea I know I need them for a roller cam
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
bamaboy0323
Sep 3, 2015 06:07 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
