Vortec Heads Flowed with 2.02/1.60 Valves
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Vortec Heads Flowed with 2.02/1.60 Valves
Great numbers and on a 170cc intake. I am not sure what you have into them price wise but posts like this should make anyone even considering junk like procomp run for the hills. The best increase is on the exhaust side. usually the vortecs are weak on exhaust flow but it looks like that has been fixed.
Car: 1983 G20 Chevy
Transmission: 4L60
A ZZ9 cam will be used with Siamesed Edelbrock runners, Dyno Don Headers, ported Vortec base, 24lbs injectors, 52mm TB, 700r4 and 3.23 gears in a 91 Z28. Chip will be tune by Kevin91z at the Dyno.
Car: 1983 G20 Chevy
Transmission: 4L60
Sounds like it will be a strong runner.....Looking forward to dyno charts when it gets dialed in. Sounds like it should be in the 350 RWHP range if not a little more.
Oh yea! It also has dual cats and a 3in Magnaflow cat-back exhaust system. The A/C and all the smog stuff will be on and working.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
@ Vincent - What did the porting cost? Who did it? And is it available to anyone?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I did the porting to the intake and exhaust, Dr. J did the valves and bowl work.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
