Vacuum in my valve cover vent??
hey guys. I picked up a fairly nice 89 formula for cheap because it wasn't running right. its acting like it has a bad vacuum leak so while I was looking things over with the air cleaner off and car running I put my hand against the breather tube and it has a large amount of vacuum. I plugged it and my rpms dropped back down to 800 from around 1500. car is running better like this but still not right. my question is how do I have vacuum here?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Vacuum in my valve cover vent??
suction there is normal.but the drastic RPM change plugging/unplugging the breather is not-might have bad or missing PCV valve.
Yeah, I'd try a fresh PCV valve AND INSPECT THE HOSE GOING TO IT FOR CRACKS, HOLES OR GENERAL DETERIORATION. At idle the PCV valve shouldn't be moving enough air out of the engine to cause such a huge RPM drop just by plugging the breather hose on the other end.
I mean a lot of vacuum guys like it would suck a rag in I don't think the small hose going to the pcv could even produce this much at the much larger vent hose. but I know this hasn't always been the condition because when I got the car the filter housing had oil in it and the filter its self was nasty. all I have done so far is set the timing clean the housing and replace the air filter changed the oil and replaced the o2 and intake air sensors
and put a new throttle body and gaskets on the intake
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Sounds like you got a real big intake manifold leak, bad gaskets or big crack, like your manifold vacuum is getting into the valley area of your block
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
it blows smoke on startup but not really after that. I know the motor is tired it has 144k on it and im sure they wernt nice. was hopping to be able to drive it for a bit though
Car: 1983 G20 Chevy
Transmission: 4L60
As for PCV.....I prefer using fixed orifice PCV valves for say a 2003 5.3 Tahoe. They don't rattle at idle and IMO its a better setup.
ok Im not sure how they work so here is a thought I also removed my cat while problem solving to see if it was plugged. would having the tube that comes off the cat for the AIR system wide open cause any kind of vacuum?
NBrehm
Aug 25, 2015 11:49 PM
