Hot Starter ??
Old Jun 15, 2014 | 09:32 AM
3rd Gen Guy's Avatar
From: Cambridge, Minnesota... EHHH LOL !! I'm actually a hillbilly from Memphis Tn !!
Car: '84 Camaro
Engine: rebuilt 305 with extras
Transmission: Nothin special !
Axle/Gears: 3.23, NOT ENUFF, LOL
Hot Starter ??
I rebuilt my 305 adding many new parts but when I shut it off, it is hard starting and the starter struggles . It has headers, bored .040 over and a mild cam, new starter, new 650 cca battery.
I tried adding a wrap around the starter, NO CHANGE. I've been told it needs a hi torque starter due to the header heat and another guy said put a bigger battery in it and add a metal heat shield to it .
So I'm wondering if any of you had the same problem and how you fixed it before I throw more $$$ at it.
Any input is greatly appreciated, THANKS
And Happy Fathers Day to all dads here !!!
Old Jun 16, 2014 | 07:20 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Hot Starter ??
I have longtube headers and run one of the mini starters and have no issues. I've read a lot of stories on here of people with the bigger starters and headers having heat soak problems though.
Old Jun 16, 2014 | 07:42 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Hot Starter ??
starter for an LT1. PMGR, can be had for around $100 from RA.
Old Jun 16, 2014 | 05:00 PM
Car: '84 Camaro
Re: Hot Starter ??
Whats the diff I an LT1 starter and a rebuilt or new aftermarket ? and what is Ra and pmgr ?
Old Jun 16, 2014 | 05:05 PM
naf's Avatar
naf
Re: Hot Starter ??
Your choice rebuilt or aftermarket.
Permanent Magnet Gear Reduction-stay away from direct drive starters, they should be outlawed
Rock Auto
I admit, though, that I recently went ahead and paid like $30 extra to buy a PMGR starter to fit my 168 tooth flexplate motor in my TA (shop for starter for '98 C1500 5.7) at AZ (Autozone). Something to be said for being able to swap it out down the road if you have trouble.
You would need one from a '96 LT1 Camaro.
Old Jun 17, 2014 | 05:28 PM
Car: '84 Camaro
Re: Hot Starter ??
So the pmgr is better than a direct drive ? Wish I knew that before I got the other one. And it won't drag when the car has been running ?
I've never had this problem b4 on other cars but I also never knew how bad the engine compartment is for airflow on a 3rd gen. I didn't have the lower air dam in when I was driving it cuz I hadn't buttoned things up and man was it warm when I popped the hood lol !
Old Jun 17, 2014 | 05:29 PM
Car: '84 Camaro
Re: Hot Starter ??
oopps !!!!!
Old Jun 18, 2014 | 06:46 AM
naf's Avatar
naf
Re: Hot Starter ??
A thousand times over.
? If the starter continues to spin, with a whining sound, after the key is turned back from start to run, it needs to be shimmed.
Old Jun 18, 2014 | 09:56 PM
Car: '84 Camaro
Re: Hot Starter ??
It doesn't just spin, it makes the dead battery sound like it needs help to crank th motor but not when I start it cold, only hot.
I'm gonna check on the PMGR starter this wk, not sure what I'll do with the old NEW starter ... GGRRR
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
