Cam for a 385 stoker
Old Jun 25, 2014 | 09:25 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
So I picked up a monte carlo ss with a 385 stroker that I plan on putting into the camaro with a HSR. The engine has less then 500 miles on it but has a flat cam lobe, so I need a new cam, I have been told the cam in the car is .525 lift, it had a good lope at 1000 rpm. Now I have been looking at some cams but I was leaning towards the comp cams CS 280H-10. Any opinions? Heres my setup right now:
385 stoker
113 aluminum heads
1.6 GMPP roller rockers
Flat top pistons
pro comp single plane intake
edelbrock 750
built 700R4 with a 3500 stall converter
4.10 gears
Old Jun 25, 2014 | 09:48 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Cam for a 385 stoker
Call the cam manufacturers hotline and ask them. I would however switch over to a HR cam, less chance of going flat on you, but if you must use a flat tappet cam get a zinc based lube for install and some zinc additive or it will be flat again in short order.
Old Jun 26, 2014 | 09:15 PM
Car: 86 Z28
http://www.summitracing.com/parts/cc...14-4/overview/
this is the cam that was in the engine
Old Jun 26, 2014 | 09:32 PM
Car: 86 Z28
http://www.summitracing.com/parts/cca-cl12-213-3
thinking about this one
Old Jun 26, 2014 | 09:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
It runs on pump gas? That thing is near 12:1
Gonna need a big stick to bleed that compression off. Sure it has flat tops?
Old Jun 26, 2014 | 10:31 PM
Car: 86 Z28
I'm not just what I have been told, the guy said it can run on 93, but should be mixed with race gas. I was running it on 93 without hearing detonation/knocking. I need to get a borescope down the plug hole. The cam appears to not have had proper break in, or just a bad lifter as the rest looked fine.
Old Jun 26, 2014 | 10:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah flat tops and 64 cc in a 3.75 stroke is 11:1. 113 heads are 58 cc and could be approachin 12:1, i didnt run the calcs. Be careful with it
Old Jun 26, 2014 | 11:10 PM
Car: 86 Z28
I don't plan on getting on it unless I'm running race gas. Might do e85 when it goes in the camaro
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
