edelbrock 1406 trouble idling
Old Mar 30, 2015 | 09:23 PM
littlecountry74's Avatar
I have a 5.7 350 1988 that was throttle body, I switched it to carbureted and put a edelbrock 1406. Motor ran perfect before, but now it will not idle below 900 rpm and the rpm's will jump from 900 to 1500 about every 30 seconds. Can anyone help me please?
Old Mar 31, 2015 | 01:15 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: edelbrock 1406 trouble idling
Did you change the distributor?
How are you regulating fuel pressure?
What caused you to make the swap?
Old Mar 31, 2015 | 02:05 PM
Night rider327's Avatar
Car: 1988 Camaro
Adjust the elec. choke and the fast idle.
Adjust the idle mixture screws using a vac gauge to get the highest vac reading.
Old Mar 31, 2015 | 02:22 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
First question did you change the fuel pump or install a fuel pressure regulator? The Carb only needs 5 to 8 lbs of fuel pressure the TBI uses a lot more. You could be flooding it.
Old Mar 31, 2015 | 08:08 PM
Tested the fuel pressure its at 6 psi. It has a mechanical fuel pump. It was a throttle bodied motor in another car. All the vacuume lines should be hooked up correctly. The only times the motor sounds like it's running well is at 2500 or greater.
Old Mar 31, 2015 | 08:16 PM
midias's Avatar
Did you put in a new distributor? The TBI one wont work with a carb
Old Mar 31, 2015 | 08:22 PM
Yes is has a mad ignition.
Old Mar 31, 2015 | 09:16 PM
midias's Avatar
Are you using vac advance?
What is the base timing?
What is the timing at 3k rpm?
Old Mar 31, 2015 | 09:59 PM
midias's Avatar
Have you checked for vacuum leaks?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
armybyrd
Dec 5, 2015 09:22 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
