wrong accessories?
Old Apr 6, 2015 | 05:41 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
wrong accessories?
Finally ready to install my power steering pump, crank pulley and alternator for my 355 swap. I took all the pullies and accessories off of an 82 camaro's LG4 although I took the water pump and alternator to autozone to make sure I replaced them with the right parts. The problem is my water pump pulley holes don't line up with the new water pump and it looks like the pulley will sit a few inches farther out then the crank pulley? Any ideas?
Old Apr 6, 2015 | 05:50 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: wrong accessories?
I have an 83 (v-belts, intact, no AC) and my 87's old accessories sitting (converted to serp.)
Post up pics of what you have and I'll try to help.
Old Apr 6, 2015 | 08:23 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Not sure how to post pics on here but I've got the alt bracket on the top passenger side, the bracket right below that, two brackets near the top drivers side for the powersteering and I believe that's it off the top of my head. Not sure what the issue is since everything worked on the 305.
Old Apr 7, 2015 | 06:58 AM
killer777's Avatar
Car: 1989 Firebird Trans Am
Engine: 355
On the message box, there is on the top middleish, a yellow box with a mountain and sun, click that, and upload from device (ie computer/ phone)
Old Apr 7, 2015 | 07:35 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Old Apr 7, 2015 | 07:37 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Old Apr 7, 2015 | 07:41 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Old Apr 7, 2015 | 07:42 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
These are all my accessories mounted on the old 305. Now that I look at the pic I realize I was using a different water pump pulley yesterday. :/
Old Apr 7, 2015 | 07:47 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
New engine. Trying to remember how the bracket under the alt mounts near the water pump.
b_the_j's Avatar
Car: 92 RS
The water pump for serpentine setup is reverse rotation (driven by the backside of the belt) GM changed the bolt spacing on the pulley so it cant be used with a v-belt pulley. As far as the belt alignment goes there is about a thousand different setups you will have to rummage pulleys till you find one that works.
Old Apr 7, 2015 | 08:16 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Old Apr 7, 2015 | 09:15 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Ok so I'm retarded - had the water pump pulley on backwards so I should be good once I figure out how the bracket to the left of the pump bolts on. Any suggestions? My water pump bolts are too far recessed for the bracket to bolt directly to it. Now that I look at it, I'm guessing there was an ac compressor mounted on the top right so I should be able to take those two brackets off as long as I'm able to have everything spaced correctly so the belts/pullies line up.
Old Apr 7, 2015 | 09:26 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
In this pic you can see where the bracket underneath the alternator mounts. Looks like it bolts direct to the water pump?
Old Apr 7, 2015 | 09:29 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Old Apr 7, 2015 | 11:27 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Looks like the wrong water pump .
Old Apr 7, 2015 | 11:41 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
+1
Old Apr 7, 2015 | 01:35 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
How would I know which water pump to get?
Old Apr 7, 2015 | 02:43 PM
Engine: Lb9
Transmission: M20
85-87 camaro or firebird,tuned port . Look at rock auto.com to see manufacture part numbers and pics. There will be the mounting tabs for the alternator.
Old Apr 7, 2015 | 02:45 PM
Engine: Lb9
Transmission: M20
GATES Part # 43099 Click for more information about this part
{#511588, 511589, 551121} Includes: 3 Gaskets, Plug
Part Image
$18.29
Add to Cart
CARDONE SELECT Part # 5511115 Click for more information about this part
{#10048917, 12522033, 12529305, 14085847, 474029, 88894341, PWP520} Includes Gasket One of our most popular parts
with Standard Pump
Part Image
$18.88
Add to Cart
AIRTEX Part # AW1121H Click for more information about this part
Includes Gasket
OPTIONAL HEAVY DUTY VERSION
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
355tpipickup
Sep 28, 2015 05:50 PM
