problem RPM jumping
Old Jun 7, 2015 | 06:03 AM
tarouty's Avatar
problem RPM jumping
Hello I need some help for my 91 camaro
the RPM jumping and there is no stability
http://cdn.top4top.net/d_e2a178d88a1.mp4
Old Jun 7, 2015 | 08:45 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Re: problem RPM jumping
Have you visually inspected all spark plug wires for burns and made sure they're all snapped on the plugs and distributor cap and coil?
Old Jun 7, 2015 | 09:02 AM
tarouty's Avatar
I inspected the wires on the cap only
But I discovered when inspected for the wires , oil leak from the power steering gearbox
Old Jun 7, 2015 | 09:04 AM
Car: 1989 Camaro
That wouldn't cause the problem but some burnt wire or wires grounding on your exhaust manifold would.
Old Jun 7, 2015 | 09:21 AM
tarouty's Avatar
Thank you for your help
I'll take the car to the electric to check wires
Old Jun 7, 2015 | 10:21 AM
Car: 1989 Camaro
But you were already checking the spark plug wires at the distributor. Just follow them down to the plugs checking for burns and making sure they are snapped onto the plugs...
Old Jun 7, 2015 | 04:10 PM
tarouty's Avatar
can I remove the wires from the coil one by one ?
no problem If I remove it ?
Old Jun 7, 2015 | 04:27 PM
Car: 1989 Camaro
Removing them 1 by 1 will make it easier to put back correctly after visual inspection.
Old Jun 7, 2015 | 04:42 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
bad pickup coil on dist will cause the tach to jump.
Old Jun 8, 2015 | 03:07 PM
tarouty's Avatar
Thanks for help
the image very excellent its help
But it is difficult to reach the spark from top of the engine
I'll try
Old Jun 9, 2015 | 03:10 AM
tarouty's Avatar
Car turn off when I move to R or D
Old Jun 9, 2015 | 08:28 PM
Car: 1989 Camaro
you check all the wires yet?
Old Jun 10, 2015 | 06:51 AM
naf's Avatar
naf
misfire at the plugs won't cause the tach to jump.
Old Jun 10, 2015 | 03:15 PM
tarouty's Avatar
not yet because cant reach all sparks
Old Jun 10, 2015 | 09:53 PM
357 Camaro's Avatar
Car: 92 camaro/99 gmc Z71
Engine: 357/5.3
Transmission: built 700r4 4500 stall/4l60
Axle/Gears: 4.56/?
You should be able to reach around enough to check them. I had this problem a lot with my z28 before selling it. They would get on the manifolds. Some of the plugs you have to get under the car to get.
I know that when the wire did get burned it would run fine till it grounded out on the manifold car would lose power overheat ect... That's when id get to lookin around and find the burnt wire.
Old Jun 12, 2015 | 09:47 AM
Es_91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
This could also be caused by a bad ignition module. Just had the one in my 91 go out last week. It will cause the same problems with the tach jumping and the car surging and finally stalling. It's worth taking it out and having it tested.
Old Jun 12, 2015 | 11:25 AM
tarouty's Avatar
To reach enough should I have RAMP or floor jack
I'm will buy one soon
Old Jun 12, 2015 | 11:28 AM
tarouty's Avatar
Can I fix it or need to buy a new one ?
Old Jun 12, 2015 | 11:49 AM
tarouty's Avatar
which one are the RPM regulator
Old Jun 12, 2015 | 09:10 PM
Car: 1989 Camaro
the 1 on the left is your idle air control valve. The 1 on the right is your throttle position sensor
Old Jun 13, 2015 | 07:19 AM
Es_91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I would recommend a jack since it would be more useful later on. Also for an ignition control module you would have to replace it. It's about $50.
Old Jun 16, 2015 | 01:24 AM
GraigMuller's Avatar
Car: 1989 Chevrolet Camaro IROC-Z/Z28
Engine: 5.7L/350 cu. in. V8
Axle/Gears: Borg Warner 9 bolt 2.77 posi
My 1989 Camaro IROC-Z has the 5.7L V8. I have replaced everything under the hood except the throttle body. I have even replace the IAC valve on the throttle body several times. Every now and then after driving the car on the highway for awhile and then coming into a town with a red light, I sit there waiting for the light to turn green and while waiting there, the tach tends to rev up and down and then the engine stalls. Could this mean that the the throttle body needs to be replaced? It does have 165K miles on it. FYI, I do clean the throttle body regularly. Could the MAF sensor need cleaning?
Old Jun 28, 2015 | 09:20 AM
tarouty's Avatar
Thank you iroczracer07 , naf , 357 Camaro , Es_91rs
Thanks to everyone who gave me help
It was a problem in the fuel pump
I've replaced the pump, the car is fine now
Old Jul 6, 2019 | 03:47 AM
rawatenator's Avatar
Graig, did you ever get to the bottom of this? I have the same problem on my 92 V8 Firebird
Old Jul 10, 2019 | 05:55 PM
79Daytona's Avatar
Hey GraigMuller. did you ever fine out what was wrong with your 89 IROC-Z . The reason I ask I got a 92 Camaro Z28 5.7 TPI it kinda dose the same thing.
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
CORV3TT3
Aug 23, 2015 11:26 AM
