89 Camaro. No crank no start
Old Jan 11, 2016 | 05:51 PM
Joey Sosa's Avatar
Car: 1989 camaro
Bought my 89 Camaro Rs 305 from a friend and when he had it it was running just fine when he had it. Said previous owner bypassed the neutral safety switch and one day it started smoking and since then the car wouldn't crank or start. Only way it will crank is getting wire from battery to starter. Also under the steering column looks like someone before had a kill switch, toggle ignition and a remote start and aftermarket security system, but wasn't a problem when it was running. I was thinking it might be the computer but when I checked nothing looked wrong with it.
Old Jan 11, 2016 | 06:17 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 89 Camaro. No crank no start
See this is first post, welcome to the forum. In your post you mention that the neutral safety switch started smoking. Have you replaced the switch? Did you check the fuses? Do your headlights dim when you attempt to crank it. Give us a little more info on what you have done to it.
Old Jan 11, 2016 | 06:55 PM
Joey Sosa's Avatar
Car: 1989 camaro
thanks !
This all happened with the previous owner and I am still in touch with him.
Since it started smoking he never replaced the neutral safety I did however it didn't change anything. The headlights only turn on when I pull the light **** on the dash. When I crank nothing happens with the car or the lights. Since then I've gotten a new ignition switch, installed it and when I reconnected the battery the horn would go off and I had no way to stop it so I unplugged the fuse. Other than that I checked all fuses and they're all fine.
I also read about the neutral safety switch having to be set a certain way ? Any other info you might need ?
Old Jan 11, 2016 | 07:11 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Sounds like a smoked fusible link or 2 down by the starter.
Old Jan 11, 2016 | 07:50 PM
Joey Sosa's Avatar
Car: 1989 camaro
So what should I look for when going near the starter if that's it ?
Old Jan 12, 2016 | 08:30 AM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
Just to clarify, where was it smoking? Near the neutral safety switch or elsewhere?
Old Jan 12, 2016 | 08:37 AM
Joey Sosa's Avatar
Car: 1989 camaro
Yes near the neutral safety switch where he said it was bypassed. What I can see it doesn't looks fine all the wires look okay under the bezels
Old May 3, 2016 | 04:33 PM
Horn0816's Avatar
Car: '92 RS
Engine: GM 350 swap
Any luck? This sounds like my car that's been sitting for ~3 years because it frustrated me so much. Mine melted the yellow wire going into the starter enable relay. Replaced it and bypassed the relay with no luck. Replaced all the fusible links too.
Old May 30, 2016 | 07:09 PM
Bill91z28's Avatar
Sounds like mine too where are the disable links
Old May 30, 2016 | 08:37 PM
Bill91z28's Avatar
Sorry autocorrect fusible links
Old May 30, 2016 | 09:05 PM
Horn0816's Avatar
Car: '92 RS
Engine: GM 350 swap
There's a block by the battery that has some and a few more on the starter solenoid.
Maverick H1L
Jan 31, 2016 08:22 PM
2012sergen11
Dec 29, 2015 03:04 PM
B4C5.7
Dec 12, 2015 08:35 PM
