Not sure what these do
Old Jan 29, 2016 | 09:43 AM
RedIrocZZ's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 C.I.
would like to know what they do when i connect them it causes the engine to stall and stutter and it spit out white smoke from the intake.
Attached Thumbnails Not sure what these do-20160128_070705.jpg   Not sure what these do-20160128_070712.jpg
Old Jan 29, 2016 | 10:00 AM
RedIrocZZ's Avatar
Engine: 350 C.I.
Re: Not sure what these do
But when there not connected the cars fine
Old Jan 29, 2016 | 11:46 AM
OrangeBird's Avatar
Car: 1989 Firebird
the first one is the connector that when disconnected puts the distributor into "base timing mode" . I don't know what the second one is because my car doesn't have that connector (something else different between the 6 and the 8 cyl cars) .
Old Jan 29, 2016 | 12:24 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
With the first on disconnected, you need to reset your base timing. Then, for the engine to run right, you need to hook it back up.... If that causes the engine to run bad, then you have a problem somewhere.
What is the second one for? Can you tell where it goes?
Old Jan 29, 2016 | 12:59 PM
RedIrocZZ's Avatar
Engine: 350 C.I.
No I haven't followed it back i will today when i get home.
Old Jan 29, 2016 | 04:11 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the second one looks like it's got something to do with the HVAC system since it goes thru the firewall above the heater box.
high speed wiring for the fan, perhaps?
Old Jan 30, 2016 | 03:00 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
The first one is called the (EST) wire/connection.= Electronic Spark Timing.
This is how its used to set your base timing to the stock configuration.
This needs to be done.
(Start car and idle until the car is at operating temp. Disconnect the EST wire, adjust timing, reconnect EST wire. Shut off car .)
Just leave yours unhooked in the beginning and set the timing then hook it up as described.
If your still having problems than at least you know the timing is set correctly.
There is another procedure that is also important called "setting minimum idle speed"
The timing has to be set to the stock setting before you can do it.
Old Feb 1, 2016 | 12:35 PM
RedIrocZZ's Avatar
Engine: 350 C.I.
Thanks for the help
Old Feb 2, 2016 | 02:46 AM
Engine: TBI,5.0
If the engine light comes on after setting the timing/messing with the EST wire just unhook the battery for a few minutes.
Also , take it easy on the car for the first 20 miles or so. Drive normally , don't "hot rod" it. That will give the ECM time to relearn the new settings.
Old Feb 4, 2016 | 12:41 PM
RedIrocZZ's Avatar
Engine: 350 C.I.
The Black square when hooked up my car wont start. so i dont think it goes to HVAC
middian
Carburetors
19
Jan 28, 2016 08:00 PM
Iroccer
Jan 28, 2016 10:33 AM
Abubaca
Jan 27, 2016 09:12 PM
1988_f-bird
Jan 26, 2016 09:53 AM
Anthony13
Jan 25, 2016 02:41 PM
