Help glowing headers!!!
Old Dec 26, 2001 | 09:05 PM
GTABANDIT's Avatar
Need Help Headers glowing red to bright orange. I have base timing set @ 6 deg fuel press @ 42 with out vac and im running ford svo inj with a custom burned ed wright chip . Do you guys think it is a rich or lean conditin and can i work it out or do i need to contact ed for more prom tuning?
Old Dec 26, 2001 | 09:08 PM
GTABANDIT's Avatar
Sorry left out valuable info inj are 30lbs and engine is 383 cid with modded slp and accell pieces . note eng runs fine as if no vacuum leaks .
Old Dec 26, 2001 | 09:40 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
That is a lean condition.
Old Dec 26, 2001 | 10:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It could also be severely retarded timing.
The simple thing to do would be to try tuning the motor; i.e. vary the fuel pressure up and down and see what happens, vary the timing up and down and see what happens, etc.
Old Dec 26, 2001 | 11:07 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
from what Ive been told and experienced when its hot like that its lean, try to give it a little more gas or adjust the advance on the distributor, but off the top of my head your timing sounds about right.
Old Dec 26, 2001 | 11:19 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Well, sounds like you're running lean to me. I guess if you run it like that and get a hole in your rod from running that lean then you'll know.
I would recommend uping the fuel pressure to about 46psi.
I would also recommend getting an AutoXray scanner or some sort of scanner to scan the car.
You can get a factory refurbished AutoXray for $89.99 plus shipping at http://www.autocheckup.com/refurb.htm
Old Dec 27, 2001 | 05:15 PM
GTABANDIT's Avatar
Thanks for the help guys other useful info i left out is i installed a walbro 255lbs unit in the tank. Ive been sprayin the nitrous without any problems but i think im gonna cool it for a while till i get this worked out. thanx for the info on the scanner and all your suggestions !!
Old Dec 27, 2001 | 06:21 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think you're running rich...unburnt fuel is now burning in the primaries.
Have a O2 sensor hooked up you can monitor?
Old Dec 28, 2001 | 12:33 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I think you are running rich too. Been there, done that. Unburnt fuel is burning in the exhaust primaries.
You didn't say whether you had the car programmed for the injectors yet? Do you? If not, then that is the problem.
Tim
Old Dec 28, 2001 | 01:36 PM
GTABANDIT's Avatar
Thaks for the reply as a matter of fact i had 30lbs accell in the set up originally i had three croak on me from the get go . I replaced them with the ford svo 30's i havent had the prom recalibrated for the svo's i do understand they have a higher flow rate . Sounds like i need to call ed . Thanks guys
Old Dec 29, 2001 | 03:56 PM
Hank Brote's Avatar
Have you got a new cam? It is unburnt fuel in the exhaust...... Probably caused by timing (ie. cam timing).
Old Dec 29, 2001 | 06:49 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Definately check your timing....I had the same problem with mine and the timing was way off. Also make sure you have the correct timing tab.
I'm also going to agree with some of the other guys and suggest that you up your fuel pressure to like 46-48.
gta892000
Aug 11, 2019 11:16 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
redformula88
Oct 14, 2015 06:08 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
andy74
Sep 3, 2015 08:41 AM
