4th Gen Gas Tank Fuel Pump Hole Access
Old Dec 20, 2017 | 06:32 PM
scottwrightF1's Avatar
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
Hi,
I have done some searched and I only can find most of the information is from a 3rd gen gas tank fuel pump hole cut access. I cannot find any information where I can cut a hole to access the 4th gen fuel pump. I thought I saw some information on here before showing the measurements where the hole should be cut at.
I would appreciate if anyone have any information showing where the 4th gen hole measurements showing where it should be cut at.
Thanks.
Old Dec 20, 2017 | 06:46 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: 4th Gen Gas Tank Fuel Pump Hole Access
who would have thought Thirdgen.org would be mainly about 3rd generation info...
Old Dec 21, 2017 | 06:26 PM
Found a YouTube showing how he cut the hole to have access to the 4th gen tank.
Still searching to find more information on how to mark up the hole where to be cut at.
Old Dec 21, 2017 | 07:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Absolutely no need for a access hole with a plastic 4th gen tank. The tank drops in 5-10 min with the two straps. Thats why its worth while to swap one in if you ever need to do fuel pump swaps, whch generally is not gonna be offen lol a walbro will typically outlast the car
Old Dec 21, 2017 | 08:37 PM
Thanks, I am aware of that the 4th gen tank is easy to drop out, but going through taking the tank out a number of times in the past. It just too much and dont have the time or space. I am just trying to get some ideas what I should do if I should cut the hole or going through dropping the tank again.
Old Dec 21, 2017 | 08:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Well the rear end area is basically same on both gens
Old Dec 21, 2017 | 09:00 PM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
You didn’t say what year, and it varys, certain years are twds the front while others to the rear. Be more specific. My 2000 is twds the rear, I cut cause it was quick, and put a 255 in.
Old Dec 21, 2017 | 09:34 PM
My is a 1988, and the plastic tank is from a 1999. Sorry I should have mention it earlier is a "plastic tank".
Did you do any measurement where to cut the hole?
Old Dec 21, 2017 | 09:49 PM
irocwagon's Avatar
http://www.gonicd.com/intankinstall/...mpinstall.html
http://www.worldisround.com/articles/12533/photo14.html
I can’t guarantee on the cut. I have an 88 and 00 cut but won’t be able to measure till wknd
https://ls1tech.com/forums/fueling-i...imensions.html
Old Dec 21, 2017 | 09:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
All the plastic tanks have the pump housing towards the rear of the tank
Old Dec 22, 2017 | 08:03 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
https://www.youtube.com/watch?v=COOLesyiVNc
This guy did EXACTLY what you're looking to do and the thumbnail for the video pretty much shows you exactly where to cut. Stop asking and just hack the car up already.
Old Dec 22, 2017 | 10:49 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Its a 3 foot by 2 foot hole...right behind the rear seats
Old Dec 22, 2017 | 12:00 PM
Saxondale's Avatar
Car: 84 Z
I'm gonna chime in for no good reason other than open mind.
I'm all about stock setups and originality. But correcting GM's cost cutting measures shouldn't be an issue. GM would rather put the burden on the consumer to pay for tank drop than pay for an engineered access door.
If done right, an access door in a thirdgen is appropriate in my opinion, and particularly because it can be done on the most accurate appearing restoration without compromise to the restoration. The number of pristine cars on this forum where it would not be appropriate is only a very small percentage of the total cars.
Similarly, there are very few pristine cars on this forum where subframe connectors would not be appropriate. But for most of the cars is something that corrects another GM engineering and cost cutting flaw.
Old Dec 22, 2017 | 12:10 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
"If done right, an access door in a thirdgen is appropriate in my opinion"
Agree with you Saxondale
And there's some hacked up stuff out there.
Old Dec 22, 2017 | 12:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Lol i dont think alot of guys on here have plastic 4th gen tanks, else they would know how simple and quick you can drop these tanks.
I can somewhat understand an access panel for a stock steel tank but not the 4th gen plastic ones
Old Dec 22, 2017 | 01:33 PM
irocwagon's Avatar
This isn’t my car, but I cut my 00 by this
Attached Thumbnails 4th Gen Gas Tank Fuel Pump Hole Access-87326e67-e16f-4f12-91d2
Old Dec 22, 2017 | 06:05 PM
Thanks, I appreciate the information.
Old Dec 22, 2017 | 09:35 PM
GeneralDisorder's Avatar
If done right, an access door in a thirdgen is appropriate in my opinion......
I agree with you in principle, but as a mechanic I am also VERY aware that this is not a unique problem to third gen F bodies. In fact MOST cars don't have an access panel. We just dropped the tank on a Nissan X-Terra, and I've done countless others on GM, Ford, and Chrysler cars, trucks, and vans. Only car maker I know of that has ALWAYS included an access panel is Subaru.
I'm not condoning it - but it IS industry standard. If only they used better pumps and sending units....
GD
Old Dec 23, 2017 | 06:00 AM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
...which generally is not gonna be offen lol a walbro will typically outlast the car
This has been my point, most access hole questions I've read here and on Facebook always defend their decision with some form of the "I've replaced too many and don't want to drop the tank anymore" story. Buy a quality part the first time, install it properly, and then you don't have to do it again.
Old Dec 27, 2017 | 07:00 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Just dropped my 4th gen tank this weekend. Took less than 10 min lol didnt even lower the rear end just put jackstands under the axle. Tank slides out so easily
86FyrBrd
Jul 29, 2020 09:03 AM
SneezeCheese
Jan 29, 2015 03:11 PM
tony_cogliandro
Fabrication
192
May 31, 2010 07:28 AM
un4givin89
Oct 6, 2001 04:20 PM
