Fuel pump will not turn off...HELP!!!
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
the car I am working on is a 91' V6, every time I turnoff the key, the fuel pump keeps running, I replaced the relay, it still runs, so now I have to disconnect the + cable each time the car is turned off, even my fan keeps running, not getting anywhere right now, I tried running a By-pass, but after running for 25 minutes, the inline switch melted, I am thinking it might be a different relay, since there are 3 of them in one place on the drivers side, or a faulty ECM?
Engine: 4++,350 & 305 CIs
Re: Fuel pump will not turn off...HELP!!!
Is the oil psi switch a 3 wire on those or 1 wire?
Next time it happens, unplug the oil psi switch. If it stops, the internal switch in there is bad. If it stays running, the relay is bad.
Engine: Classified
I just had the oil sending unit replaced, and even replaced the relay, but on the drivers side fire wall, there are 3 relay, I replaced what should have been the fuel pump relay, but now I wonder if they are out of place?...I'll try unplugging each one to see what is defective next.
Engine: Classified
Car: check
Engine: check
Transmission: check
On a '91 V6 the fuel pump relay has a short red wire with a fast-on connector on the end. See if you can tell which relay that goes to, it will be the fuel pump relay.
Since you also state that the fan runs too, it sounds like someone did some re-wiring. As the fan relay coil loses power at key-off. At least in a stock configuration.
RBob.
RBob.
Engine: Classified
RBob.
RBob.
Engine: Classified
RBob.
RBob.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
This is a way to identify the fp relay from the other relays.
Engine: Classified
I went to unplug all 3 relays, the fuel pump still ran, while the car was off, so I am lost as to what should be done next?
Engine: Lb9
Transmission: M20
The fp can only get power through the relay or ops. Sounds like you have a wiring issue since you just replaced the ops.
Engine: Classified
what would happen if I unplugged the Oils ending unit?...would the car still run?
Engine: Lb9
Transmission: M20
Engine: Classified
still stuck, the sun light is gone, just gonna wait til tomorrow and try to see whats happening and then trouble shoot my problem?
Engine: Classified
A few things I am just now realizing, 1. my key only now turns forward and not back to ACC to use the radio only, 2. I wonder if the new oil sending unit is defective? 3. where is this so called (off switch) located for the fuel pump?....going nuts here*
Engine: Classified
I just looked again and noticed the oil sending unit lock tab is broken off, would that cause a problem?
Which could be the problem.
There is no "off" switch for the fuel pump that you can turn off with a button or lever. The switch I'm referring to is inside the oil psi sending unit. I have had a couple fail and keep the fuel pump running. Even when the relay shuts off correctly.
Engine: Classified
Great!...1st thing to do is swap the Oil sending unit, trouble shoot from there, then play around with replacing the Key Lock cylinder*
Engine: Classified
Well, tried replacing the Oil sending pig tail, still got the same result of it running, but I realized I had bought a single wire after market sending unit several months ago and found it, so when it gets dry enough, I will put that in and do a rewire and if all goes well, the pump should only come on when the key is turned* >>>Fingers Crossed<<<
berlinettakid
Feb 8, 2005 03:05 PM
