TV Cable keeps going out of adjustment
Old Feb 20, 2018 | 12:27 AM
AstroFirebird's Avatar
Car: 88 Formula 350 and 92 Z28
My TV cable in my Firebird will go out of adjustment occasionally. Like every week or two I'll be driving and all of a sudden the transmission will shift much later than it should. So I let the car cool down and readjust the TV cable then it shifts correctly. After another week or two it'll do the same thing again and I have to adjust the TV cable again. I cannot figure out why the TV cable keeps coming out of adjustment so frequently. I'm thinking about replacing the cable all together but does anyone have any ideas?
Old Feb 24, 2018 | 08:21 AM
Vader's Avatar
Re: TV Cable keeps going out of adjustment
It seems the plastic ratchet mechanism may have lost tension or is stripping. If you can get a good replacement, it may be worth tampering with the ratchet mechanism to block/clamp it in place. If things go badly, you can always replace the assembly.
Old Feb 24, 2018 | 10:24 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
the price of a new cable is cheap and easy insurance compared to burning up the trans, get one that's the correct length and youll be good to go
Old Feb 25, 2018 | 04:15 PM
Do you by chance have a part number of a TV cable?
Old Feb 25, 2018 | 04:17 PM
TylerSteez's Avatar
Engine: 383 stroker
They’re different lengths depending on what you have (carb, tbi, tpi). Just go on rock auto and select what you have and you’ll be fine
Old Feb 26, 2018 | 02:12 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
i believe my tv cable is out of adj because the trans shifts late also. what is the correct way to adj it
Old Feb 26, 2018 | 02:24 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
https://www.thirdgen.org/forums/tran...djustment.html
Old Feb 26, 2018 | 02:32 PM
TOM305T/A's Avatar
thanks bob88gta
wiggin
Dec 19, 2009 05:20 PM
RentGuy
Jun 4, 2005 03:49 PM
WaynesRS
Oct 27, 2002 09:47 PM
Flash84Z28
Car Audio
Aug 15, 2001 08:02 PM
89ROC
Nov 24, 2000 05:50 PM
