What can cause piston and head damage like this?
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hi Guys,
I had a knocking noise from my motor and when I tore it apart I've found this.
I checked the rods and the bearings are good, there's no play, but something has been hitting/smashing/bouncing around in there.
Piston doesn't seem to protrude out of the cylinder, but it's close.
It's put a crack in the #7 cylinder wall so it looks like either resleeve or new block, but I just wanted to know what could cause this becfore I rebuild and it happens again.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What can cause piston and head damage like this?
Too much timing perhaps.
Looks like debris went thru intake valve and got stuck in cylinder before it finally when out exhaust. Have seen carb. or air cleaner screws eat up a cylinder, head and piston. Even broke spark plug tips.
JOE
JOE
Car: 1986 Iroc Z, red, t tops
Engine: Gm Performance ZZ3
Transmission: Built 700 r4
Axle/Gears: 3.73 Detroit Locker 10 bolt
Looks like something metal ended up in the engine, like a screw.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With that kind of damage, something went through the engine. Could have been a small screw. Maybe a piece of a cotter pin.
Engine: 4++,350 & 305 CIs
I'd also have the rod checked for being bent
Thanks, will do.
So far I'm looking at:
Cam replacement/forced upgrade - XFI 280 $400
Cylinder Sleeve $100
Heads resurfacing $160
New Pistons 4.145" $270
Rings $100
$1030 for a motor I barely got to run. Fun fun fun. Still tossing up whether to pack it in and just put a stock ls1 in there instead.
Rings $100
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
100% some foreign object went thru it. Same damage on my sbc when turbo blew up
Awesome, thanks for the confirmation.
Well not awesome, but it's comforting to know I'm not the only one who has seen this kind of carnage.
I think I will rebuild, as I'd rather have an awesome 6.6L monster than a stock 5.3LS1, and I'd still have to fab up mounts/brackets and exhaust anyway.
Fun times ahead.
Car: 87 IROC L98
So many people think damage can be cheaply fixed. Even something simple like a spun bearing means a lot of repairs to fix it properly. In the end, it's cheaper to just buy a new engine. Even a stock replacement engine is cheaper than a rebuild. I picked up a catalog from the local GM dealer last week. You can buy a bare bones shortblock. Install your own camshaft, heads and intake. The bottom end is complete and that's what's going to cost the most to fix.
Every time I hurt a race engine I knew it would be a few thousand to fix it again. Biggest replacement was when I cracked the block in the mains area. $3000 for a new Dart block plus machine shop work.
And people think their 2nd hand sbc motors in need of a rebuild are still worth $2500, its ridiculous.
For a cracked sbc block that is only useful for a dummy fit, they still want $200-300. Crazy.
Car: 89 Iroc-z
Transmission: TH400
To be honest if the cylinder wasnt cracked, and the head valveseat wasnt damaged, a simple brush hone job in the cylinder plus a sanding cartridge roll to the head chamber and piston crown to smooth off any sharp edges, i would throw it together and run it lol
In fact i ran mine for half a year with damage to chamber and piston crown because i didnt know it ate anything motor ran so good
MarkB
Pacific Northwest Region
56
Aug 1, 2002 11:00 AM
