lt1 starter on l31 block, starter bolts too long
Old Apr 16, 2018 | 05:47 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Hey guys, I went to install an lt1 starter on my new 383 stroker l31 block and bought the average 3 pack of starter bolts.
the longest bolt is about 5/8" too long and the shortest bolt is about 3/16" too long. These bolts match the original bolts that were on my stock 305 starter too.
anyone ever ran into this before?
Old Apr 16, 2018 | 05:55 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: lt1 starter on l31 block, starter bolts too long
The last lt1 starter I bought came with the bolts (used)
You might ask this seller about the length.
https://m.ebay.com/itm/95-97-Camaro-...0AAMXQq8BQ8iTL
http://nastyz28.com/threads/starter-bolt-issue.172519/
Old Apr 16, 2018 | 06:24 PM
TylerSteez's Avatar
Engine: 383 stroker
thanks tuned, I'll message the seller and see if he can get me measurements. I've seen that thread on nastyz28 earlier and I'm thinking it might be worth it to go to the dealership and see if they can get the bolts for a 96 camaro.
I just bought a second pack at autozone that appeared to be the right length but the thread is different, I was too caught up in the fact that they looked like the right length and said GM on them to check if the thread was correct
Old Apr 16, 2018 | 06:29 PM
You need the bolts that go with the starter. Block doesn't matter.
Old Apr 16, 2018 | 07:03 PM
Drew's Avatar
96 Camaro LT1 from the GM parts database. Maybe the length will help...
BOLT. Starter Motor
Part Number: 14037733 ; 14037733
BOLT(OUTBOARD HOLE)(3/8-16 X 1.66)(W/SERR 300M). BOLT(OUTBOARD HOLE)(3/8-16 X 1.66)(W/SERR 300M)(W/1998234). BOLT,STRTR(3/8-16 X 1.33). BOLT,STRTR(OUTBOARD HOLE)(3/8-16 X 1.33).
BOLT. Starter Motor.
Part Number: 12338064 ; 14037732
BOLT,START MTR. BOLT,START MTR INBD HOLE. BOLT,STRTR(3/8-16X4.33). BOLT,START MTR INDB HOLE. BOLT,START,MTR INBD HOLE. BOLT,STRTR. BOLT,STRTR(INBOARD HOLE)(3/8-16X4.33).
Old Apr 16, 2018 | 07:06 PM
TylerSteez's Avatar
Engine: 383 stroker
BOLT. Starter Motor
these are the part numbers I came up with through google as well so they're looking like the right ones, my sister works at a GM dealership so shes gonna try and get them for me tomorrow. thanks for the help
Old May 1, 2020 | 06:08 PM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
I couldn't locate that short bolt anywhere online on its own, and couldn't get the correct length at the auto parts stores either. So after much aggravation I started looking at ARP bolts, and they have the correct set for the 4th gen f-body LT1 starter. It's ARP 430-3516 for the 6 point set. They also offer these bolts in 12 point, but my car tool kit is 6 point so those aren't for me.
Old May 2, 2020 | 09:11 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
last time I needed some, just got them at autozone, hanging on the rack
Old May 2, 2020 | 09:19 AM
TylerSteez's Avatar
Engine: 383 stroker
it’s been a couple years so i can’t remember what part numbers i used but i did end up finding the ones that worked
Old May 2, 2020 | 05:58 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
This link has the correct length and threads for the bolts. A lot of guys are unaware that chevy went to metric threads in the starter bolt holes in the early to mid 80's. Putting the wrong hardware in a block can crack the outside bolt hole/ear. Notice if you buy a starter at the parts stores, some of them end with a part number-"M". That would be the metric starter. You can put a metric starter on an older block, but just make sure to use the correct 3/8-16, knurled hardware. The metric and SAE threads are very similar looking. Just thought i would pass on info. https://www.crankshaftcoalition.com/wiki/Starter_motors
intex1982
Theoretical and Street Racing
Nov 21, 2019 09:01 PM
RSFreak
Pacific Northwest Region
May 28, 2013 07:03 PM
L695speed
Aug 22, 2012 05:06 PM
jak
Alternative Port EFI Intakes
Oct 4, 2011 07:05 PM
Darkshot
Aug 5, 2009 07:35 PM
