Starter "heat soak"
Car: 88 camaro iroc
Engine: 5.0 TPI
Transmission: 5 spd mannual T5
Axle/Gears: 3.27/ 9 Bolt
Starter "heat soak"
Ok, so we all know about heat soak in starter motor prevent the engine from turning over when hot. Which i already read some post of how that work or happens. But what I don't understand is how does a hot starter motor solenoid or "heat soak" shuts off the engine while driving? Can anyone tell me how this happens.
Re: Starter "heat soak"
A hot starter does not cause an engine to stall while driving. You are confused. Either you lost fuel, spark, or air - one of the three things needed to sustain engine operation. The starter has nothing to do with it.
GD
GD
Car: 88 camaro iroc
Engine: 5.0 TPI
Ok, yeah I am comfused. I would drive my car for 20 to 30 minutes and car would shut off, I would a tempt to fire it up and nothing happens. I try again after 10 minutes and it would start right away. I did replaced the big starter motor with a mini powermaster starter, and drove it an hour and It hasn't shut off me again. So I'm not sure what the problem was. All I know is the car runs great again
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The stalling sounds heat related. Checking for spark, injector pulse and fuel pressure when this occurs would be a good start.
I suppose you might have had a heat induced poor connection to one of the fusible links coming off the starter solenoid supply. But barring that you probably have an intermittent spark or fuel delivery like Tuned Performance suggests. Be on the lookout for the stalling issue to return at some point.
GD
GD
Engine: Lb9
Transmission: M20
You would think if it’s a fusable link you would loose all power to the inside of the car. Dash lights ign power. Trending Topics
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
If it continues to die when it warms up. I'd check your ICM as stated above. Or ignition coil. A loss of spark will shut down your engine right away. Unless by "nothing happens" on a restart you mean it won't even crank. Than I would def look at the starter or wiring.
ViciousZ
Nov 26, 2001 02:26 PM
Ray87Z
Sep 30, 2000 01:12 PM
