Recommended sealant for water pump & bolts?
Car: 1985 IROC-Z
Engine: 383
Hello all,
I'm finally going to do my water pump tomorrow, wondering what the recommended gasket sealant and thread sealant are?
Mike
Mike
Car: 90 Formula / T-tops
Transmission: MD8
Re: Recommended sealant for water pump & bolts?
don't think gasket sealant is needed if you have smooth surfaces to mate, otherwise black permatex - little dab will do ya. for threads, only needed if they go into water jackets, use permatex white thread seal
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
I've always used a light application of good old Permatex High Tack. Make sure to clean off all the old gasket material and sealer first.
Engine: LB9 305
Transmission: AT
I'll have to try it on bolts, into water jackets, some day.
NOT Indian Head. Whatever else, NOT that.
Teflon paste is the perfect right stuff for bolts. Permatex 200 (brown gooey gunk), or Ultra RTV, or Right Stuff, is good for the gaskets.
Those parts move around constantly. You need sealers that stay flexible forever, which Indian Head does NOT no matter whether your great grandpa used it on his Model A or not. You don't want regular RTV either, as it eventually tears and turns into little useless *****, especially on the threads.
Darkshot
Aug 5, 2009 07:35 PM
TomP
Feb 26, 2001 10:12 AM
