Installing engine with headers on it?
Car: 89 IrocZ
Engine: L98-ish
So, head gasket change turned into pull the motor and freshen it up with a T56 swap...sigh,,,okay, so has anyone put the engine in with shorty header on ? I'm picking up a set of Edelbrocks next week, would like to just put the motor together and drop it all in,,,if it'll work,
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Installing engine with headers on it?
With Dynomax headers I was running at the time I wasn't able to, if your gonna try you might want to remove the steering shaft.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Only SLP will go all others right side only
I don't even think SLPs will go... in my car they didn't fit between the AC box and the steering shaft. There might be some variation in individual cars, or year models, or whatever, in that area though.
Given that the steering shaft is quite eeeeeeezy to R&R though, it could be said that "almost" any will "almost" fit that way.
But it's usually still eeeeeeeeeezier and much less risky to just lay them in the engine bay and drop the motor in between them, like everybody else does.
But it's usually still eeeeeeeeeezier and much less risky to just lay them in the engine bay and drop the motor in between them, like everybody else does. Joined: May 2012
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
So my Hooker shorties right side header can be bolted up prior to engine installation? Cause that's the PITA side, for sure. Left side is a piece of cake.
Car: 89 IROC Z
Engine: 5.7L
Axle/Gears: 2.77 PosiTraction
Please clarify, which is passenger side and which is drivers side, I just want to be sure as to what you are saying. Thanks.
Car: 89 IrocZ
Engine: L98-ish
I was mainly thinking about the rear most bolts and accessing them,
BTW, anyone use these?
https://www.proformparts.com/locking-bolts
If as advertised, kinda beats getting the last C-clips in.
Um , , Driver's side is the side of the car where the steering wheel is , , , Passenger's side is where the pretty girl sits .She don't get a steering wheel nor stick shift to play with , So .....
Engine: L31 350 TPI
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Side bar note if you put the engine in from the bottom you can have everything on including the AC compressor. Bolt the motor to k member 1st lower case over it. I set the motor,trans & k member on a 4 wheel dolly then lower case on. Have to watch sway bar to front crank pulley closely. Done it both ways now prefer out the bottom easier with a 2 post hoist. But can use cherry picker to lower front end over the car.
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
After engine in the car w/o ac or steering shaft, R side POC, L side POC...
Car: 89 IrocZ
Engine: L98-ish
I recall that's the way a lot of guys did it with Mopars back in the day.
Don't have a hoist though, but will look it over, maybe clear a path for the forklift.
I do need to do some front suspension stuff on it as well, gonna think hard about doing it this way.
Car: 1989 Trans Am GTA
Transmission: M28 T56
Thats how 4th gen guys do it, out from under the bottom.
Done it several times with a 4th gen Camaro.
Though I've always come out the top with my GTA, but definitely easier to go out the bottom.
Sadly, I have LT's now, and those must come out before you do anything.
Hecubus
May 4, 2002 07:11 PM
RedIrocZ-28
Aftermarket Product Review
Mar 31, 2002 11:00 AM
