88 gta need help after diy engine rebuild
Old Jul 4, 2021 | 02:26 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I am today cranking it
It has fuel pressure
and after I can smell gas
I checked my spark plug wiring firing order 2 times
it's not starting
I think I'm 180 off I heard a pop 2 times
I'm gonna go crank it again and listen and maybe try quick start
just a bit
if it's still not starting it has to be 180 off
what's the easy way to do it
Ty for the help advice
Old Jul 4, 2021 | 03:34 PM
bensbaby's Avatar
Engine: 383 built
Re: 88 gta need help after diy engine rebuild
it's not starting
just a bit
maybe the China eBay 30lb inj are bad
may be siezed from sitting outside for a month
I will check for spark to just to make sure
Old Jul 4, 2021 | 03:44 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
eBay knock off injectors are the worst. I quit tuning them there almost non responsive.
Old Jul 4, 2021 | 04:43 PM
bensbaby's Avatar
Engine: 383 built
they worked ok for me so far
if I spray quick start in the engine and it fired then I know there the issue ?
Old Jul 4, 2021 | 04:51 PM
Engine: Lb9
Transmission: M20
Are basics are checked , compression, correct ignition timing, fuel pressure, spark, injector pulse with noid light?
Old Jul 4, 2021 | 05:37 PM
bensbaby's Avatar
Engine: 383 built
it has fuel pressure
it just backfires 2 times so I stopped
it has to be the 180 out
I was super sure it was on
I had the valve cover off and watched 1 it looked like if was tdc
this happens everytime I take it apart
It was running perfectly just smoking oil minority
I put new rings and new rod bearings and put new gaskets
the problem is I can't check the compression in all 8 unless I take the headers off
I just got new reflex gaskets
I can't only snake the tester in past the 2 driverside 2 passengers side front cylinders
Old Jul 4, 2021 | 06:00 PM
Probably the wrong #1 TDC; the #1 TDC where the #1 exh valve is closing and the int is opening (which is also #6 firing), instead of the #1 TDC where it fires.
Eeeeeeeeeezzzzzzy enough; line up the timing marks more or less, lift the dist acoupla inches, turn the crank exactly 1 turn, drop the dist back in. Piece o cake.
Old Jul 4, 2021 | 07:32 PM
bensbaby's Avatar
Engine: 383 built
ty I will let you know
Old Jul 5, 2021 | 06:15 PM
bensbaby's Avatar
Engine: 383 built
I just took 4 hours and redid the 180 out dist timing
and it started first crank
instantly
zero gas pedal
and I shut it off
I forgot to hookup my wideband o2 so it had a leak I heard it
it nerds coolant and oil top up
I'm gonna let it run tomm with me watching for leaks
thank God
I wish there was a way i could get past the 180 out forever
does anyone know good ideas so if only does this everytime
bensbaby
Feb 24, 2020 04:41 PM
my1988gta
Apr 14, 2017 06:27 PM
Purple 92 SS
Jan 8, 2007 10:09 AM
JeffD
Mar 19, 2006 04:52 PM
