Did I Cause Damage?
Old Nov 16, 2021 | 10:40 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Did I Cause Damage?
1984 Trans A/M built for Canadian Market as "Export Only". No ecm that I can find.
The carb is off this car for rebuild. While replacing the outer window sweep, I inadvertantly left the key on while testing the power windows up & down with new the sweep, and drained the battery. Would this cause any damage to the HEI Distributor internals - coil, pickup?
I know with the old points setup & external coil, that the coil and coil could fry.
Old Nov 16, 2021 | 11:48 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Did I Cause Damage?
No , you didn't fry anything HEI wise, recharge your battery and you'll be good
Old Nov 16, 2021 | 01:10 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
the ECM should be on the passenger side under the dash foot cover. You should be able to see a bunch of wires going out to the fender.
Old Nov 16, 2021 | 01:21 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
he went through this earlier. I learned in the process that exports didn't have ccc qjets. He has a purely mechanical qjet and a vacuum advance dist.
Old Nov 16, 2021 | 01:27 PM
72buickgs's Avatar
Car: 1984 Trans AM
Thanks for the replies. Much appreciated...
Old Nov 16, 2021 | 05:23 PM
1989karr's Avatar
Engine: 3.4 / 5.0
damnn id like to have one of those!!
Old Nov 16, 2021 | 06:38 PM
vorteciroc's Avatar
Top Answer: 1
I miss the days when I could see an F-Body roll off of the Assembly-Line with a non-CCC Quadra-Jet... and a Distributor that is not missing its advance Weights,Springs, and Vacuum-Diaphragm.
Sadly (as you just pointed out) the last of them were exported to other countries, where the Government is far less retarded.
Old Nov 26, 2021 | 07:03 PM
72buickgs's Avatar
Car: 1984 Trans AM
Carb came back from the rebuilder. With the battery full recharged, & a little gas dumped in the carb bowel via the vent tube, the car started up. Thus, no damage to the distrib.
suburbansamy
Carburetors
Jul 29, 2018 12:16 PM
DirtyCanadian
Jul 4, 2008 11:37 PM
1tpi
May 1, 2005 01:15 AM
FOX-GTA_89
Nov 5, 2004 05:35 PM
