Bad Charcoal Canister or just Purge Solenoid? Hissing Noise/Gasoline Smell
Old Mar 1, 2022 | 10:14 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
So today, I noticed that I hear a hissing noise coming from the front of my car. The front driver's side behind the head lights. All of the hoses were attached to the charcoal canister but there was still a hissing noise. Also after even a 15 minute drive, that part of my car smells like gasoline. Could it be my charcoal canister is going bad?
Also could a bad charcoal canister cause a surging idle/stalling when the car is warmed up?
Lastly, does anyone still make a charcoal canister for our cars? I cannot find one anywhere. Not O'Reilly's, NAPA, Autozone, Rock Auto, Amazon, Advance, etc. Only the Purge Solenoid.
Most of the threads with part numbers are from the mid 2000s...
Old Mar 2, 2022 | 06:28 AM
Ccoe1's Avatar
Car: '88 Iroc
Engine: 5.0L TPI
Transmission: Borg Warner WC 5 Speed
Axle/Gears: 10 Bolt, 7.625" 3.08
Re: Bad Charcoal Canister or just Purge Solenoid? Hissing Noise/Gasoline Smell
https://shop.thirdgenbargainbarn.com...amaro-firebird
Old Mar 2, 2022 | 06:40 AM
Engine: LB9 305 TPI
That's the vacuum ball. I need the charcoal canister.
Old Mar 2, 2022 | 06:50 AM
Ccoe1's Avatar
Car: '88 Iroc
Engine: 5.0L TPI
Oops, not sure what is was thinking there. I havent had my coffee yet.
Old Mar 2, 2022 | 07:47 AM
Engine: LB9 305 TPI
Haha I hear ya.
Old Mar 2, 2022 | 09:30 AM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
Axle/Gears: 10 bolt, 3.73
I'm not able to find a part number either, it looks like the canister for your year range might have been discontinued. They are rebuildable with a bit of work though: https://www.thirdgen.org/forums/tech...ebuilt-my.html
I know that's not what you're looking for, but maybe it will be helpful!
Old Mar 2, 2022 | 10:27 AM
stron3's Avatar
Car: 87 Camaro Z28
I had a similar issue with a strong fuel vapor smell near the canister. I roughly followed the instructions in the above link to rebuild mine, except I used a coping saw to slowly and carefully cut the weld at the top of the canister until it broke free. Mine was still full of charcoal but it was definitely over-saturated. After cleaning an re-filling with new charcoal I used epoxy to glue the top back on. Before proceeding make sure the valve on top is functional because it can't be replaced.
Old Mar 2, 2022 | 11:15 AM
Engine: LB9 305 TPI
I'm surprised it's been discontinued. I guess I'm going to have to do this rebuild.
Old Mar 2, 2022 | 11:45 AM
Engine: LB9 305 TPI
Question does this pigtail that mounts on top of the Charcoal canister have a part number?
Old Mar 2, 2022 | 01:03 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Also make sure the check valve isn't leaking. its the small, round thing, about 2" in diameter with 3 hoses coming out of it. its a plunger style valve, and built pretty cheap. its in your photo.
Here is an option for you if you want to start fresh and new, the part number to the connector to the solenoid is also in this link. Everything was plug and play for a 1990, even the canister bracket. check your year to be sure.
https://www.thirdgen.org/forums/tech...ter-purge.html
Old Mar 7, 2022 | 03:04 AM
malc1080's Avatar
Car: 1987 z28 T Tops
I’m in the same process of finding a whole vapor canister. My 86 camaro builds up a lot of pressure where the tank pops from expanding and when i remove the gas cap it releases a lot of pressure. This causes my car to shut off when it’s been running for a long time. I can’t believe I can’t find a new vapor canister and only the valve and vapor canister filter on rock auto. But autozone and orieily don’t carry them. I had to find my answer on this forum and I see it’s true that they just don’t make it anymore. Really disappointing.
KR81
Feb 25, 2023 02:46 AM
1roc89z28
Jul 27, 2011 11:25 AM
freeyasoul03
Aug 19, 2006 06:28 PM
84Z28_5.7ltr_V8
Nov 23, 2002 03:41 PM
