396LT1 new dyno numbers
Car: 97 Z28
Engine: 396 LT1 518whp All Motor
Transmission: 6spd
Axle/Gears: 4.10 LSD
I know this is a 3rd gen forum but maybe you guys will still like this. After rebuilding the engine with some magic tweaks, I finally got the car back on the dyno for some pulls. To say the least we were all blown away by how much power this beast put down. The build specs are in the description of the video. Enjoy
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 396LT1 new dyno numbers
I know this is a 3rd gen forum but maybe you guys will still like this. After rebuilding the engine with some magic tweaks, I finally got the car back on the dyno for some pulls. To say the least we were all blown away by how much power this beast put down. The build specs are in the description of the video. Enjoy https://youtu.be/omTxcroUWMI
Car: 97 Z28
Transmission: 6spd
First let me say I’ve been following your threads for years and you do great work bro keep it going. Yes I built this engine myself if you have instagram check out my videos and follow me please This car has come a long ways…when I first built this 396ci ten years ago it was only able to turn out 411whp…after many many tweaks and mods we finally broke the 500 mark…after all the blood sweat and tears I couldn’t be happier
Car: 1983 G20 Chevy
Transmission: 4L60
First let me say I’ve been following your threads for years and you do great work bro keep it going. Yes I built this engine myself if you have instagram check out my videos and follow me please https://www.instagram.com/reel/Cj6oZ...d=YmMyMTA2M2Y= This car has come a long ways…when I first built this 396ci ten years ago it was only able to turn out 411whp…after many many tweaks and mods we finally broke the 500 mark…after all the blood sweat and tears I couldn’t be happier
I am sure some of my stuff could make alot more power if it were in something lightweight where I had freedom to really up the cam and induction sides.
Car: 97 Z28
Transmission: 6spd
I just think it’s so much more impressive to build big power with what you got…everyone now a days just does LS swaps cuz it’s easy to make power…even the ford guys just gave up and do LS swaps it’s sad. Years back I built up a 355 TBI for my buddies 91 RS. We were able to crack 320whp but the factory computer would make the engine hit a brick wall. I’m still looking for a 3rd gen to build the TPI I’ve always wanted…396ci with a Super Ram intake
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Engine sounds great. What exhaust are you running and do I hear boost? Or is that sound coming from something else?
Car: 97 Z28
Transmission: 6spd
True dual with Borlas….All Motor pump gas 10.7 static compression…I think it’s the rollers you hear
Car: '90 RS
Engine: 377 LSX
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 97 Z28
Transmission: 6spd
Dual 3” the drone is not bad at all and the sound it makes when its screaming past 6k is unmatched
fast355
Late 90s vortech intake YES! I love it
What’s that in?
fast355
What’s that in?
Car: '90 RS
Engine: 377 LSX
Car: 1983 G20 Chevy
Transmission: 4L60
I had 3" duals on my Hemi Ram with a X-pipe. It sounded awesome up toward 7K. Sounded wicked with open cut outs too.
very cool! i have the 396 from the thunderchicken firebird that was in gmhitech performance. it made a little over 500 whp rattling the moly off the rings on pump gas. (there was a miscalculation when the pistons were ordered, and compression was at least a full point higher than expected)
i recently rebuilt it but have not made use of it yet.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 97 Z28
Transmission: 6spd
Car: 97 Z28
Transmission: 6spd
Must be nice to have 15% or so driveline loss rather than ~25%. 415 cubes would have equaled that out a bit for me. Then again I think I could pull the body off, put a seat on the frame and it would still weigh close to what a F-car weighs. My rear end alone is nearly 600 lbs with the drums. 4L85E is over 250 lbs. Puts my driveline at like 1,400 lbs.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Nice numbers. AI heads and cam are no joke, they got the sbc lt1 figured out well
those are similar numbers to my buddys old 406 miniram t56 build with old ported afr 210’s and a 242/248 solid roller
Car: 1983 G20 Chevy
Transmission: 4L60
new setup will be 398", Trick flow 212cc 21 deg. heads, 24x/25x hydro roller with solid lifters, 14:1, single plane on e85.
Car: 97 Z28
Transmission: 6spd
I thought about going with solid lifters also…didn’t go through with it but maybe I’ll try it when I swap intake manifolds…I have an Edelbrock RPM LT4 that I need to port and swap
only reason i am going solid lifters is i had a brand new set of morel drop ins that i never used that were sitting around for years. when i got this engine, it was missing the lifters, so i just went with the morels i had instead of buying a new set of fancy hydro ones. i am still tossing around the idea of putting the original ported LT1 intake/monoblade back on it... i know who has it and i might be able to sweet talk them out of it...
