Some help finding parts?
Old Jun 28, 2023 | 08:01 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Hello, while doing spark plugs I've just found that I've had a sensor wire burn through! I don't know how long its been like this, but can someone help me find the right sensor and pigtail?
Its between cylinder 1 and 3.
Weird thing is I don't think I've had any problems due to this? I'm pretty sure my gauge works, and I replaced the one for the fan on the passenger side.
88 305 TPI
Thanks for the help!
Old Jun 28, 2023 | 09:19 PM
Re: Some help finding parts?
That's the sending unit for the temp gauge.
You can't get one with that "mushroom" style connector on it, that I know of. Other than that, it's as ordinary as can be. Should be in stock at the parts store down on the corner. New ones come with a regular ¼" slide terminal instead, takes the ordinary kind of connector.
Old Jun 29, 2023 | 08:44 AM
Annihilate's Avatar
Engine: 5.0
Much appreciated!
Old Jun 29, 2023 | 01:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
newer style maybe nail head or spade
https://www.ebay.com/itm/37294371238...mis&media=COPY
Old Jun 29, 2023 | 03:09 PM
Annihilate's Avatar
Engine: 5.0
Any idea how I could test the current sensor if its just the wire that needs to be replaced?
Old Jun 29, 2023 | 04:48 PM
Engine: Lb9
Transmission: M20
Would probably have to look at fsm ohms vs coolant temperature .
Old Jun 29, 2023 | 07:12 PM
Yup; pretty much the only way.
Although, if it's not shorted and not open, it's probably OK. Should be a few hundred ohms at typical room temperature.
Old Jul 11, 2023 | 08:12 AM
Annihilate's Avatar
Engine: 5.0
So I just got my car started again for the first time in a month, and I had to be sure, but my temp gauge still works even without this sensor?
I'm fairly certain it's worked for as long as I've had it, and I don't think I've ever had it connected, as I've been around the spark plugs and the intake plenty.
How is this possible?
I'm gonna get a new sensor and wire today, but curious nonetheless.
Old Jul 11, 2023 | 08:40 AM
OrangeBird's Avatar
Car: 1989 Firebird
I'm left wondering this;
You are 100% certain the gauge works. And yet that is the sensor for the gauge, with no wire connected to it. Could perhaps that sensor had died long ago, and a previous owner couldn't get it unscrewed from the head, and then went and installed a new sensor elsewhere on the engine?
Other than that, , , I got nothing.............
Old Jul 11, 2023 | 09:01 AM
Vader's Avatar
Was that sensor in the right or left head?
Old Jul 11, 2023 | 09:30 AM
Annihilate's Avatar
Engine: 5.0
Yeah, the gauge settles at 0 cold. And incrementally increases as it warms up.
The sensor came out pretty easy, I didn't take it out all the way cause I don't have the replacement yet.
The sensor is located next to the first cylinder on the driver side.
Old Jul 11, 2023 | 04:20 PM
Annihilate's Avatar
Engine: 5.0
Well the mystery remains, I've replaced the sensor and pigtail. Hopefully that does something.
I'm beyond mad at the car right now, and its on stands and nearly out of gas. Can't let it run too long.
jbrooks6104
Jan 17, 2023 03:03 PM
Mrossevelt
Dec 5, 2021 10:36 AM
Jonas_76
Aug 8, 2007 11:51 AM
I H8 WWD
Apr 28, 2007 10:45 AM
raptere
May 22, 2003 11:08 PM
