Is G-Tech still around?
Old Nov 17, 2023 | 12:08 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Are they still a thing or is something else available?
Old Nov 17, 2023 | 12:43 PM
B4CYA's Avatar
Car: 85 Z28/87 IROC-Z/92 B4C
Engine: Twin turbo LS9/SC LS9/L98
Transmission: RPM T56/T56 Magnum/700R4
Axle/Gears: 9"/Dana 44/10 bolt
Re: Is G-Tech still around?
Dragy is the go-to in-car performance meter now. https://dragymotorsports.com/
Old Nov 17, 2023 | 12:44 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Thanks!
Old Nov 17, 2023 | 12:45 PM
B4CYA's Avatar
Originally Posted by EDGE
Thanks!
You're welcome. It's a really cool piece. The roll racers use it to log 60-130 times and a lot of people have ran them in their cars at the drag strip. They are surprisingly accurate.
Old Nov 17, 2023 | 12:54 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Can you get and idea of Horsepower/Torque from them?
Old Nov 17, 2023 | 01:17 PM
B4CYA's Avatar
As far as I know the Dragy doesn't estimate horsepower.
Old Nov 17, 2023 | 05:23 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Dynolicous measures hp and plots you some nice graphs. You can even measure your shift interval.
Old Nov 18, 2023 | 12:32 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I watched a video of someone using a dragy at a track and it was pretty much spot on with the Et and MPH.
Old Nov 18, 2023 | 10:11 AM
Torque Pro will use your phone's accelerometer to measure ... acceleration. You tell it what your car weighs. From there, it will calculate the power numbers reasonably accurately. Costs about $5.
Old Nov 19, 2023 | 09:45 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
I use draggy and it's quite accurate!
What I like is, you can practice your launch only and it will still log your 1/4 mile as you continue on at slow speed. So you don't have to worry about law enforcement or pushing the engine all the time. Even if 1/4 mile is very slow on purpose, I still get the 60 foot.
Here's an example of full on 1/4 mile on street. They are from different passes. One is 0-60, other one is 1/4 mile
I have not used it simultaneously at the track but it is very close to what I do at track. I vary +/- 0.3s and +/- 1.5mph at track anyway depending on air and launch. Next summer I plan on using it at the track and maybe post results.
My best so far at track
2QUIK4U
May 9, 2004 06:41 PM
omcrider
Aftermarket Product Review
Nov 18, 2003 05:29 AM
brian89transam
Aug 28, 2002 11:20 PM
Nasty_Bird_'90
Theoretical and Street Racing
17
Aug 13, 2002 03:16 AM
