Wondering if certain parts will work together
Old Jan 13, 2025 | 08:08 AM
Vhanta97's Avatar
Car: 1984 Camaro Berlinetta Starship Ed.
Engine: Worn out SBC 305 5.0L V8
Axle/Gears: Stock
I'm about to start working on a 1984 Berlinetta Starship Edition with a carbonated 305, but want to put on a TPI. I was wondering if anyone knew if the 350 TPI module would work on a 305. I'm new to the terminology so I apologize for my lack of knowledge lol
Old Jan 13, 2025 | 08:46 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Wondering if certain parts will work together
Not exactly sure what you're asking.
Your best bet for now is to do some reading in the stickies here:TPI - Third Generation F-Body Message Boards and try to get yourself up to speed a little bit.
Old Jan 13, 2025 | 11:36 AM
TPI itself is exactly identical in every way between the 305 & 350, except for the injectors, the PROM, and the knock sensor.
The angle that the center 2 intake bolts on each side go into the heads changed in 87, so a slight adapting might be required there.
Old Jan 13, 2025 | 12:01 PM
Vhanta97's Avatar
Axle/Gears: Stock
What would happen if I used a 350 PROM on the 305? Just curious.
Old Jan 13, 2025 | 12:56 PM
The fuel and ignition timing curves are different. A 350 won't run as well as it should with the 305 curves. I don't know about the reverse. Probably about the same except in reverse. (where the 305 PROM would make a 350 run lean, a 350 PROM might make a 305 rich, for example)
Old Jan 13, 2025 | 01:16 PM
Vhanta97's Avatar
Axle/Gears: Stock
One final question, probably answering my own question, I'm assuming the PROM will replace the carbureted engines ECM? Would I search for an ecu on eBay or the PROM?
Old Jan 13, 2025 | 01:25 PM
No.
You'll need the entire harness that goes with the TPI, which will replace the carb one. You'll need the TPI ECM as part of the swap. It's completely different.
Old Jan 17, 2025 | 03:31 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
As Sofakingdom said, you will need the entire TPI harness and the ECM. Stay away from 85 TPI, it is specific for that year only. 86-89 is Mass Air Flow (MAF). 90-92 is Speed Density (SD). You will also need a Prom specific for the engine you are installing.
Good Luck,
Fred
drsnac
Oct 13, 2024 11:10 AM
Shane4524
May 8, 2012 09:18 PM
86_WS6_Trans-Am
Jan 21, 2007 11:23 PM
86FOURSPEED
May 25, 2002 08:22 PM
mike2468
Feb 17, 2002 10:42 PM
