GM Diagram?
Old Jan 30, 2002 | 04:18 PM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
GM Diagram?
Does anyone know where to find a diagram for the steering column. I had to take it apart and i found some things that are broke and i was wondering what all of them do.. thanks
Old Jan 30, 2002 | 08:40 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
oh man, that sucks, steering columns are like some of the worst things in the world when it comes to rebuilding them. I've done two of them (both just to tighten the three screws that keep them from wobbling). Its a PITA to not mix things up. Unfortunatly though I don't have any diagrams for you, but if you tell me where your stuck I may be able to help.
Lata, Mike
Old Jan 31, 2002 | 07:32 PM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
hey thanks... well i was taking out the ignition switch and i found that there was a broke peace that had to metal rods on it. one gold and one silver. they were not touching but i was wondering what they did. they were past the signal assembly and everything. its kind of hard to explain. also i broke the wire off my horn assembly by an accident so do you know were i could find the ring with the wire to the horn. thanks alot...
Brandon
Old Feb 1, 2002 | 11:50 AM
burntblues's Avatar
Car: 1989 Camaro RS
Look what I found...
I thought I left this stuff at home, but it looks like I did bring it with.
I didn't know whether or not you had a tilt column or not, so I'm giving you breakdowns of both. I'm Once you get the number tell me and I'll give you the name and part number. I can help you with the horn button and stuff too, but I need more info about your car, including whether or not you've got airbags, controls on the wheel, transmission, etc.
standard column is first...
Hope this helps you find the parts....
Mike
Old Feb 1, 2002 | 11:52 AM
burntblues's Avatar
Car: 1989 Camaro RS
here they are as attachments:
Old Feb 1, 2002 | 11:56 AM
burntblues's Avatar
Car: 1989 Camaro RS
Here's the tilt:
Old Feb 1, 2002 | 04:13 PM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
wow!!
well the horn part is #6 on the diagram. and i dont think i need the two metal clips because they are still on, but the plastic covering the bottom is what broke. i just need to know what they do so i can replace them if i need too. they look like part # 14 or #15. and one quick question. if i were to get a new steering wheel, like grant or somthing, do they come with a horn kit. thanks a lot.
Brandon
Old Feb 1, 2002 | 04:55 PM
burntblues's Avatar
Car: 1989 Camaro RS
ok, the part# for 6 is 26029509.
As for the other parts, I don't really know too much about them, here's what my parts manual says:
If you have a
#14 is the ignition key warning switch 26022717
#15 is the is the clip that retains the ingnition alarm switch. 7830376
As for the horn, I don't think that they come with the grant steering kit, you may be able to get one, but not that I know of. A lot of people will wire a button up to the back of the steering wheel, I've never done it though...
If you got anymore questions man, just holla,
Lata,
Mike
InfernalVortex
Apr 20, 2021 11:31 AM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
timonator
Sep 11, 2015 05:11 PM
