Are these rods any good?
Old Feb 7, 2002 | 04:49 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
http://cgi.ebay.com/ebaymotors/aw-cgi/ebayISAPI.dll?ViewItem&item=601794603&r=0&t=0
Are the rods in the link above any good?? Is that a good price???
Old Feb 7, 2002 | 05:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes they are excellent rods. Overkill for most street motors. Heavy too. Note that they are bushed for floating pins.
Old Feb 10, 2002 | 09:54 AM
Car: 1991 Firebird
Engine: 427 LSX
Ok, what rods would you recommend for my 406??? Price is definately a consideration?? (LT1 intake, and 244, 244 cam with mods in sig)
Old Feb 10, 2002 | 11:14 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Unless you plan on spinning the engine past 7000 rpm, stock rods with polished beams, shot peened, resized and have ARP bolts will do fine.
Old Feb 10, 2002 | 02:37 PM
SoCo80p's Avatar
the i-beam and chevy pink rods are also good choices, i got these same rods for my 406, the eagle h-beam is about the best rod you can buy, but agian my 406 is much more build then yours is from what you've said so they would not be needed in your case, but that is a fantastic price on them, they sell in jeg's for 499.99 a set.
Old Feb 10, 2002 | 07:24 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
can't hardly beat these for the price
http://cgi.ebay.com/ebaymotors/aw-cg...tem=1803790367
rebuilding a stock rod will cost you almost as much.
They will need clearancing for most hot cam 400s.
this guy often also has some good deals
http://cgi6.ebay.com/ebaymotors/aw-c...d=dirttrack1km
Old Feb 11, 2002 | 09:05 AM
Car: 1991 Firebird
Engine: 427 LSX
I am just concerned about the weight of the H beam rods. They are 100 grams heavier than Eagle SIR rods. Is this a big deal? Tempest, how built exactly is your 406? How fast is it?
Old Feb 15, 2002 | 09:34 AM
Car: 1991 Firebird
Engine: 427 LSX
ttt
Old Mar 2, 2002 | 12:47 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Here's the rods I bought recently:
http://cgi.ebay.com/ebaymotors/aw-cg...tem=1808395851
What you guys think?
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
