LOL Am I running rich~~!
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My dad and I are going to do a full tune up in the Spring. The cars just sitting in the garage so i started it
Download!
Seemed worse then usual, maybe cause it was freezing outside.
Just thought id share the video
Download!
Car: 99 Formula
Axle/Gears: 342
That's a lot of smoke. I'm hoping I can buy one of those digital cameras that record video. My GFs room mate has one, pretty cool, hopefully during spring I can bring my car up here and get some vids of it.
Car: 1988 IROC-Z
Engine: 427 SBC
My digi cam takes great pics, great movies, but it dosent record sound to well. As far as the smoke, thats because It is freezing here today and the car wasnt warmed up
In the summer, my car blows no smoke, not even at start up
(Just some black when its reved which will be fixed)
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Seems like a lot of black smoke to me, but hard to tell over a video.... I would say it is a bit on the rich side, but if it is really cold out and the car is in open loop, I can understand it being a bit rich. You should try slappin a scantool on it and see how the BLMs look. Do you have an AFPR? If so, maybe drop the rail pressure a bit.... Did it smell like gas big time?
Car: 1988 IROC-Z
Engine: 427 SBC
Whats a AFPR? Im a newb.
My dad says my problem is that I have a stock chip with a 160 stat in it. But I will hopefully fix the runnin rich problem in the spring (12 MPG, good thing its a week end car
)wow you got a sweet car!
Yeah, that's a lot of smoke.. and 12mpg really sucks for a fuel injected car. AFPR is adjustable fuel pressure regulator. Maybe you need to replace your coolant temp sensor in the front of your intake manifold... What kind of camera is that? I wouldn't put a 160 degree thermostat in a thirdgen either.. try 180+.. Next time I change mine Im going to use the stock 195 because my car runs so damn cold.
Car: 1988 IROC-Z
Engine: 427 SBC
It is a cannon s110. It takes REALLY Good photos! Its kind of expensive though.
The guy I bought the car from had a 160 in it with a jet chip. Then he took the chip out and left the 160 in I believe.
Whats wrong with your car running cold? I thought TPI liked cold?
Car: 99 Formula
Axle/Gears: 342
TPIs have to reach a certain temp to reach closed loop mode. Or something like that. I though 160* stats weren't good for a stock computer.
Hey I'm runnin rich, I think? I got 11mpg, woo hoo! I've got an 89 TPI 350 IROC-Z. How is it possible that my car would be running rich, isn't there sensors that should tell me its running rich? Or shouldn't it adjust to not being rich? Are my sensors messed up? If they are, shouldn't I be getting a Check Engine type thing? What are some causes to running rich?
