A/C removal
Old Mar 11, 2002 | 09:17 PM
3gc's Avatar
3gc
Car: Z28
A/C removal
I'm removing all my A/C "stuff" from my v6 Camaro to paint the engine bay. I want to know how to remove the big box that's on the firewall, on the passanger side with the blower motor on it. I have the top cover off. I don't where or how to get to the bolts for the bottom portion. It seems that I would get to it from inside but I don't see them anywhere.
Old Mar 12, 2002 | 12:28 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
There are 2 bolts holding the botton. They are located inseide the car on passanger side. Take you fllor mat off and pull the carpet out a bit. Get a flashlight and you should be able to see them.
Good luck.
Old Mar 12, 2002 | 04:31 PM
3gc's Avatar
3gc
Car: Z28
I found them. There were 3 bolts on mine. I was looking for them there but I didn't think to pull on the insulation.
Old Oct 26, 2003 | 12:50 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
OK, stupid question.....what do you do when you can not get that last bolt off, by the distributor? It is a washer with a bolt on it. I think mine might be stripped! It keeps on turning and nothing happens. Any suggestions? Back from the dead huh!?!? thanks
Old Oct 26, 2003 | 07:23 PM
3gc's Avatar
3gc
Car: Z28
Wow, this is an old post. I'm not really sure which bolt your refering to as i haven't messed with the heater box in over a year and a half but you could alwasy drill the bolt out.
Old Oct 26, 2003 | 09:19 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Yeah this is an old post! lol I am talking about the bolt on the far right hand side, closest to the distributor. It is a bolt on a washer, which spins on a type of screw, only mine does not screw all the way off! Also, i tried prying it off but the fiberglass started to crack, and i wanted to sell this stuff so i really don't want to break it. I think it is stripped. Any other ideas? thanks
Old Oct 27, 2003 | 11:40 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
To remove most stripped bolts, I try to turn the stripped fastener (the screw) and pry the object (the heater box) away from the head of the screw. It most always works, as you get a surface for the screw threads to grab on to.
Old Oct 28, 2003 | 05:26 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
That last one is either a stud or a bolt that's bolted from the inside. Check inside. You may need two people to get the nut off. No pun intended.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
