Help He Starter Wont Turn Off!!!!!
Old Mar 12, 2002 | 09:19 PM
89Irocz23's Avatar
well guys I went to start my car and it never wants to start anyway. have to crank it like 3 minutes for it to start. Well I go to start it and the starter never turned off so im lik **** and take the key out. Still it does not turn off. So im like **** so I go find somehting to discnnect the battery, but by that time the battery died and smoke was coming from the starter and battery. What do I do guys I tried to hook the batt back and and it tries to start. so..do I need a new starter or whats going on?
Old Mar 12, 2002 | 09:30 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Sounds like the solenoid is sticking. Get a new starter.
Old Mar 12, 2002 | 09:51 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Solenoid is sticking, get a new solenoid, not a new starter.
The solenoid will come off of the starter by itself, take it to an auto store and have them match it up. About $10.00 to $15.00.
Old Mar 12, 2002 | 09:59 PM
ragtopcaprice's Avatar
sounds like the starter is gummed up, It's not hard to rebuild your starter, and it's alot cheaper to rebuild your own than to take it to a shop. There's only a couple of parts to the starter, the main drive,which is just a small motor with a case,W/ windings, which rarely break,a Stator , that's the round part with two little shafts on each end. There are brushes that ride on one end of the shafts, These brushes may be bad,they should be about 1/2" long,if they are shorter than that they should be replaced.The small cylinder on top is the solenoid,youcan buy just the solenoid at the parts store fairly cheap. Also when you take the starter out, bench test it , just hook it up to a battery and try it and see what happens, if it sticks on the bench you can also try the little gear on the back,that engages to the flywheel,it's called a bendix,or starter drive.Well good luck, and don't be afraid to tear it apart,that's the only way you learn, Starter parts are kinda cheap, but getting a rebuilt starter can be expensive
Old Mar 13, 2002 | 03:04 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
I had the EXACt same thing happen to me. Man, is it frustrating, and dangerous. You could just replace the solenoid, but chances are, the rest of the starter wasn't put together very well, either. I'd try to get your money back and get a new starter.
Old Mar 13, 2002 | 03:07 AM
JRoy91RS's Avatar
Engine: 355
Also, a starter that is sticking like that will bench test perfectly, because it will engage when it has power and disengage when the power is completely cut. You probably fried a few ground wires. Be sure you check the ground from the battery, the negative battery cable, and the ground strap that goes from the block to the firewall. Those are probably all fried. In fact, I had to replace ALL of my battery cables, and I'm still not quite sure that I found all of the wires that were fried. Good luck, and man, do I feel for you.
Old Mar 13, 2002 | 03:52 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I'd go and buy it all new.
Old Mar 13, 2002 | 11:24 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I had this happen to me when I was going 50mph down the road. Ya know how there are some big wires bolted to the middle then 1 little wire on the side? That little wire came loose and touched the big wires. It was the single most worst noise I've ever heard come from my car.
Old Mar 13, 2002 | 08:51 PM
89Irocz23's Avatar
well its a new starter so I proly gotta replace it anyway, but do I need to take the exuast off to really get the starter out? yeah im figuring I need to replace my ground wires.
Old Mar 13, 2002 | 09:51 PM
Blueiroc's Avatar
I had that happen on a brand new motor that was'nt even primed yet...not good and the starter was brand-new! but it was from VIP...a cheesy parts store in my area and the funny/frustrating part is I had to do this 6 TIMES! before I got a good starter....so even brand new/Rebuilt starters do this...good quality products!! anywho replace the starter, if it cranked that long it probably wont be sticking around for much longer.
Brian
Old Mar 14, 2002 | 10:40 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Bet you didn't like that noise EEEEEEEEEhhhhhhhhhh!!!!!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Formula_88AE
Sep 3, 2015 01:47 PM
andy74
Sep 3, 2015 08:41 AM
