choke light
Old Mar 19, 2002 | 03:01 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
choke light
my choke light started coming on 2 days ago, however, it only comes on between 1000-1250 rpms and at any speed...no other time. i know the choke light is also the alternator light, but my alternator is only about 8 months old. volts are good from the battery and it seems the alternator is charging fine. i doubt its the alternator because the light comes on and off and i think the light would be on constantly if it was the alt (i know because the light stayed on a while ago, replaced alt and it was fine) anyone have any ideas?
Old Mar 19, 2002 | 08:22 PM
Vader's Avatar
Curt,
You may want to check the choke heater element wiring, test the element, and check the choke relay and its connections.
Old Mar 19, 2002 | 08:29 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Mine did that one time, and I had to check with the mechanic, because I couldn't figure it out. Evidently there is a fuse that was blown that caused the light to come on--don't know where it is though, sorry.
Old Mar 19, 2002 | 09:14 PM
curt86iroc's Avatar
Car: 1990 IROC
vader, where is this choke heater element wire?
Old Mar 19, 2002 | 09:19 PM
82camaro's Avatar
Car: 82 camaro SC
It 'sounds' like the alternator isn't putting out enough at lower rpms. How is the battery? I ask because a bad battery(that still starts the car) can ruin an alternator over time. How many volts using a volt meter, not the guage, at idle.
Old Mar 20, 2002 | 11:41 AM
Vader's Avatar
Attached to the choke heater element on an E4ME carburetor (item #46):
Old Mar 20, 2002 | 02:35 PM
curt86iroc's Avatar
Car: 1990 IROC
i think you're right, 82camaro. it stalled 4 times today...all when i tried to stop the car for a turn of a stop sign. choke light came on and rpms dropped and stalled. i think its either the battery or the alternator. as soon as i get my hands on a volt meter ill let you know....
Old Mar 20, 2002 | 03:13 PM
CamaroX84's Avatar
Lol, Vader, do you have a pic for everything????
Old Mar 20, 2002 | 06:54 PM
curt86iroc's Avatar
Car: 1990 IROC
well....it was the alternator. checked the battery and it was good at around 14 volts. the wire coming off the choke was fine, so i went for the alt. put in a new one and bam. problem solved. thanks guys.....
Old Mar 21, 2002 | 07:45 AM
82camaro's Avatar
Car: 82 camaro SC
Don't test the battery with a volt meter, you need to have it load tested. Most auto shops will test it for free. Glad you figured out the problem.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
