What can i beat
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
What can i beat
I just did a 305 to 350 swap a few months ago and i'm wondering what cars i could beat or at least keep up with.Cars like LT1's? LS1's? 5.0's? or any other ones?I'd like to know ahead of time so i dont get in over my head.My mods are in my signature.
That's a big cam you have for 305 heads. Does it run well? What's your redline? You may be in the 14's with your combo if everything is tuned well. I would stay away from LS1's. LT1's are in the very low 14's stock. 5.0's are like a box of chocolates!
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Official list of things lightly modded or stock 305/350TPI cars should avoid.
LT1 Corvettes/Trans-AMs/Camaros
LS1 Corvettes/Trans-AMs/Camaros
LS6 Corvette
Z06 Corvette (Avoid this one at all costs)
Dodge Viper of any year
Mustang Cobra 99 and up. Don't know about previous years
Bullitt Mustang
Mach-1 Mustang (2003)
Neon SRT-4 (Don't laugh it will beat most of us stock)
Any Turbo DSM AWD
Honda S2000
RX-8
I can't think of anything else that should be avoided. I know there are some other things though that could go on the list.
LS6 Corvette
Bullitt Mustang
Any Turbo DSM AWD
Honda S2000
RX-8
Car: '87 Mustang LX
Engine: 5.0
slightly modded eagle talon TSi's (awd, 16 v dohc, turbo'd - stock)
Edited: Edited: i guess he mentioned them...
didn't he say he swapped 305 for 350?
Josh
Edited:
Any Turbo DSM AWD
Josh
Car: '87 Mustang LX
Engine: 5.0
Josh
Josh
406TA thinks that the cam may be to much with 305 heads.
Car: 91 Z28
Transmission: 4l80E
Actually, the machine shop suggested a higher duration cam, but i wanted a smaller one so it would be better on the street.
With that stall you can probably get quite of few things off the line. But most of them out there will catch you after that. Those being the higher RPM LT1's and LS1's. If you catch a bad driver in an LT1, I'd say you stand a chance. Past that though, not so sure.
Car: 91 Z28
Transmission: 4l80E
Does anybody have any suggestions on what else i could do to get some more power out of this.I dont really want to go into too costly of mods yet, since the engine is pretty much brand new.I think my next mod is going to be a 725 street demon carb.Right now i have the stock Q-jet. I thought with this engine i would at least be in the 13's.Im a little dissapointed in what u guys have been saying.
Originally posted by BadBowtie88
Only way to find out for sure is to hit the track with it. Once you find out where it runs, you can start looking at different options for making it faster. Or it may be fast enough, you never know when your car will surprise you.
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
'86 - '95 5.0 Mustang's (until you know what their running for mods)
Typhoons and Syclones
Turbo Omni's (seriously)
Turbo RX-7's
Supra's
GTP's
Anything with a Big Block in it (As long as it doesn't weigh over 5000lbs)
And I'm sure there is more
Later, Garrett
Car: 91 Z28
Transmission: 4l80E
Its around 10.5:1 compression.I dont have any problem using premium pump gas.But i think im going to start mixing in a little av gas just to be sure.
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
to avoid:
acura nsx
m3 or m5 (newer ones)
3000gt or stealth tt's
any italians
amg mercedes's
porches
crotch rockets (unless its a 250)
cops
acura nsx
any italians
amg mercedes's
porches
cops
Car: 91 Z28
Transmission: 4l80E
Well i did added a few more mods yesterday.(Accel super coil,ignition advance kit) Should help a little bit.But im still messing with the timing.I have to do it by sound.
recaro xfire
Jul 16, 2001 08:49 AM
