Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
what can I beat?
Old Sep 21, 2005 | 01:39 AM
5.7L OF JUSTICE's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7L TPI
what can I beat?
I always get a little confused on 1/4 mile times because of my altitude. What would my car run at a normal altitude which most of you are at. And also could I beat a 5.0 GT Mustang? Just wondering, any info helpful?
Old Sep 21, 2005 | 01:49 AM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
I don't know if you can beat a 5.0 GT, it matters what kind of condition your car is in. 1987 350's are alot different than the 90-92 ones. Your car had 220 Hp at the flywheel stock and with those mods I don't think youve passed those numbers yet. I think you're in the 14's if your car is running properly. Magazine test Iv'e read are all over the place as 1/4 mile is concerned but here is some readin for ya
https://www.thirdgen.org/newdesign/articles/vs.shtml
Old Sep 21, 2005 | 01:52 AM
Engine: 5.7L TPI
the car is definetly in tune, I think its about as good as it can be with these mods.
Old Sep 21, 2005 | 01:58 AM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
What did the Jet performance chip registor on the butt dyno?
Old Sep 21, 2005 | 02:34 AM
stu's Avatar
stu
You will run at least a full second slower than if you were at sea level. Do you go to PFI or what? I hear that track is pretty bad.
Old Sep 21, 2005 | 03:06 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Re: what can I beat?
what did your car run at the track you took it to even?
Old Sep 21, 2005 | 06:31 AM
87TPI350KID's Avatar
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
I would say your car could run a high 15 second at ALTITUDE, which means a 14 second car at sea level. As for beating stangs, if its an auto, go claim a vicotry, but watch out for 5 speed cars. I would suggest some headers and good tires, that really wakes up out TPI cars. Good luck!
Old Sep 22, 2005 | 01:20 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
you will find power in ignition timing as well it can add a few tenths of a second
Old Sep 22, 2005 | 02:14 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I don't think you want to add to your ET Timing adjustments won't reduce ET's unless it was severly off.
armybyrd
Oct 24, 2015 06:59 AM
beltran89
46
Oct 7, 2015 07:36 PM
Cameeeero
Sep 18, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
recaro xfire
Jul 16, 2001 08:49 AM
