87 octane gas
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
87 octane gas
could runing 87 octane cause me to go from a 13.2 to a 13.7 ?i run the 13.2 on a mix of 2 gal of 93 and 3 gal of 110 and the 13.7 was on a full tank of 87
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 87 octane gas
isn't grammar a wonderful thing?
try better gas and see what happens
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Re: 87 octane gas
Gas will get you places, but better grammar and spelling is for life
Re: 87 octane gas
did i ask to be made fun of
Car: 1987 Iroc Z28
Re: 87 octane gas
Hey sorry man nothing personal but after reading that initial question I couldn't understand what the heck you were asking.....
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: 87 octane gas
Lol he asked if running 87 octane would slow him down by half a second in the quarter mile. He used to run a 13.2 1/4 mile using 2 gal of 93 octane mixed with 3 gal of 110 octane. Now he runs a 13.7 1/4 mile with a full tank of 87 octane.
My response is that part of it could be the added weight of a full tank. If you ran a full tank, you ran three times the weight in gasoline that you normally do (6.2lbs/gal, 15.5 gallon tank = ~96lbs; 5 gal = 31lbs)
Re: 87 octane gas
ask bc of dedination caused by not using higher octane gas
Re: 87 octane gas
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 87 octane gas
With a 10:1 CR and aluminum heads it is very reasonable. That combo is not at its best performance with 87 (high CR and aluminum heads with a higher fuel volatility, ie low octane, = poor performance).
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Re: 87 octane gas
With 10:1 SCR you'll definetly be wanting to run at least 91, like shifty said it's a definite possibility.
Re: 87 octane gas
6/8/07 6/22/07
r/t 0.066 0.027
60 2.020 2.042
330 5.612 5.701
1/8 8.567 5.761
mph 82.99 81
1000 11.128 11.459
1/4 13.290 13.692
mph 104.31 100.91
r/t 0.066 0.027
60 2.020 2.042
330 5.612 5.701
1/8 8.567 5.761
mph 82.99 81
1000 11.128 11.459
1/4 13.290 13.692
mph 104.31 100.91
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: 87 octane gas
I noticed a small power gain, specially at higher rpms when I switched from 87 to 92 grade gas.
