New 3-core rad is in!
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
Well you just gotta see my parking spot.
I got at least 8L of Rad fluid all over the ground in the public garage, a trail of rad fluid leading to the garbage can on the other side of the garage (where i threw the old rad, hope they won't get mad). I didn't have a container to drain the rad fluid into, so...
But after 2-3 hours we finally got the rad in. Those stupid clamps were our biggest problem. It took us forever to get them off.
The rad definitely helped, but I now realized I do need a new fan switch because the fan is still turning on too late.
Thanks again Rovic for your help. If you ever need anything let me know!
They aren't turning on too late, they are turning on at the right time. You can kill 2 birds with one stone if you buy a performance chip from www.performanceresource.com this chip does help performance and it turns the fans on a lot earlier.
lol i didn't do it myself
12 minutes, good luck on my car, i got these stupid clamps on all the hoses that you can't get off for 45 minutes!
rovic/slade did most of the work :P
I just sat there and unscrewed screws and stuff :P
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Well "coolant" for one... Anti-freeze or water would also be good name substitutes.
How about the oil, do your buddies call that "engine fluid" too? How about your fuel tank fluid?
no, but....
rad fluid
brake fluid
tranny fluid
washer fluid
DUH!!!!
I call it pink stuff... my tranny, coolant and washer fluids are all some kind of pink, but the washer fluid will be changed to yellow in a few days, in the mean time it will be blue...
Either way, when I see pink stuff in the driveway, I go $#%#$#@!@#@.
Engine: LB9
Axle/Gears: 2.73's
Rad fluid... lol
I bet you call it a "rad"-iator too don't ya?
Last I checked a lightbulb doesn't "rad"-iate light. lol
Another one: "Ash"phalt or "***"phalt? It's amazing how many people get that wrong.
I just looked at my coolant jug when I topped up my Jimmy. Surprise, no "rad fluid" mentioned anywhere. I did get a chuckle out of the "performance rated" thing though.
Last I checked a lightbulb doesn't "rad"-iate light. lolAnother one: "Ash"phalt or "***"phalt? It's amazing how many people get that wrong.
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
fell off my CHAIR !!!
Well I CANNOT FREAKING believe it EASYSPEED has picked up a wrench I fell right outta my chair !!!
CONGRATS on a job well done !!!
I can hardly believe it their is hope for you yet man ! Couldn't be in better hands than with Slade he's been there and done ALL of that. Bet it feels good doin the work yourself instead of a shop eh ?
still in shock,
RP.
still in shock,
RP.
LOL I didn't really pick up a wrench.
Well actually I picked up about 8 to unscrew one bolt, but none of them fit. Lol. We were changing the resevoir for the rad (overflow thingy) and there was this bolt in the wheel well that I couldn't get off. I must've tried every single tool in slade's box, none of the wrenches worked, none of the other things worked, it was a disaster. :P
Rad fluid... lol
Rad fluid... lol
