Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Does changing an oil pan add 15 horsepower?
Old Sep 4, 2005 | 08:26 PM
dnc's Avatar
dnc
Help me prove my dumbass friend wrong. He says changing the oil in your car and your oil pan adds 15 horsepower.
Old Sep 4, 2005 | 09:25 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Sure, if you're running a 1000+ hp car
Old Sep 5, 2005 | 12:31 AM
Eric2ndGen's Avatar
No, of course your friend is right- this is especially true if you drive a Honda with one of those C-tech, or B-tech, or maybe it's V-Tech engines. Heck- those cars are so fantastic you can polish the intake and add 10hp.
Seriously, you can "free up" maybe 4-5 horsepower on an engine by installing a pan with a windage tray and a crank scraper. Changing the oil doesn't "add" anything- you don't think the manufacturers used brand-new oil when they dynoed the engine for the EPA and their marketing department? If you have 10-year-old sludge in the pan and it's stuck to everything else, changing the oil might "free" an amount of power- but it certainly isn't making "more" power because of it- with the sludge build up you just lost more of what it started with to friction.
Old Sep 5, 2005 | 07:11 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
If your oil is bad, or low, then changing it get rid of some possible friction caused by the old oil, and in tern allow the motor to run more efficiently and make more power, but no where near 15hp.
And a baffled oil pan that keeps oil in the sump area, with a windage tray can add hp to around the 10hp mark.
Old Sep 5, 2005 | 12:08 PM
(BR)G-Machine's Avatar
Heh, ya, or if your running 20,000 rpm.
Ya... every seasoned veteran uses an oil pan with a windange tray and a crank scraper, because they are trying to milk every last bit of power out of it. But I would say it's 2-3 hp... but maybe something like 20 hp if your in a corner and it saves the oil from splashing up on your crank, at 5000 rpm.
Old Sep 5, 2005 | 08:35 PM
johnyIROC's Avatar
I would agree.... it's more like 3-5HP for full on windage + crank scraper.... and you will get nothing from changing oil unless you go to a thinner oil.
Old Sep 5, 2005 | 11:26 PM
Stroked-Z's Avatar
Every season veteran does not use an oil pan with a built in scraper & windage tray to milk HP, genoius.
Oil control is very important making sure you pump is always submerged in oil....adding a windage tray/trapdoor help this.....the crankscraper, this is basically a $15 mod that requires 1 hr at the most of your "free time" and can net you most likely up to 10HP.....now 10HP for $15 is GOOD IN MY BOOK, and probably the best BANG for your BUCK you will ever get.
Old Sep 6, 2005 | 07:45 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Synthetic oil is 'supposedly' good for 2% more HP over non-synthetic.
Can't remember exactly where I got that from...I know they did a Royal Purple test in GMHTP about a year ago, might have been there.
Old Sep 7, 2005 | 09:49 PM
I guess I misworded it, I didnt mean the crankscraper and windage tray were "built in" to the pan, but every veteran uses oil control.
O and thanks for being rude about it, genius.
Old Sep 7, 2005 | 09:53 PM
double post
Old Sep 7, 2005 | 11:53 PM
Stroked-Z's Avatar
Sry was in a "mood"....sounded like you were poking fun......i took it the wrong way.
Basically a little HP here & there adds up....and 20-30HP more from little things such as port-matching, oil control, synthetic oil, etc... is cheap HP. Something that is often overlooked due to lazyness.
Old Sep 8, 2005 | 12:19 AM
No harm done.
You are totally right. The difference between good engines, and great engines is attention to detail.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
