stealth ram installation?
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
OK, WE ALL KNOW THE POWER NUMBER, AND THE PRICE, BUT WHAT ABOUT THE LITTLE THINGS? 1: WHERE ARE THE VACCUM FITTINGS? 2: WHERE DO YOU HOOK UP THE FUEL LINES?
3: ARE THERE 2 HOOKUPS FOR THE FUEL LINES, MAIN AND RETURN 4: WHAT ABOUT PROVISIONS FOR THE AIR INTAKE, AND WATER TEMP SENSORS? AND IS THERE ANY ILLUSTRATIONS ON A STEP BY STEP INSTALL OF THIS MANIFOLD?
LATER BADGTA
LATER BADGTA
Car: 1989 Iroc-Z
Engine: 350ci SBC
do a search man.............
This has all been covered before...here is the list:
Here are the parts we needed to install this.
-Used a 85 Camaro Carbureted upper radiator hose (Dayco 71028) (trimmed the ends back)
- Use a std. small block Chevy waterneck (Mr. Gasket PN 2661)
-Two 1/4" x 1/8"NPT straight barb fittings (rear of intake, MAP sensor and other items, I run only one line to MAP)
-One 3/8" x 3/8" NPT straight barb fitting (rear of intake other vacuum items)
-One 3/8" x 3/8" NPT 90 deg. barb (goes under plenum, used for brake booster)
- 2 feet 1/4" vacuum hose
- 2 feet 3/8" vacuum hose
- (1) 5/16" compression fitting to -6 male AN
- (1) 3/8" compression fitting to -6 male AN
- (2) 3-1/2 foot -6 line with female hose ends. Goes from inlet and outlet to fuel stock fuel lines which are cut from underneath car, the two compression fittings are installed on the stock fuel line.
- (3) 1/4" vacuum plugs for EGR solenoid and throttle body
- (1) large clamp
All the vacuum ports are machined into the plenum. The current lowers don't have the late style center bolts machined, but I am getting future ones machined correctly to fit both. Can't say when for sure. Used the stock air inlet.
You lose EGR and we didn't hook the coolant to the throttle body. Need to use the small cap GM HEI. Coil mounted with stock bracket in stock location.
Didn't have to modify any wiring.
Also the fuel lines are attached to the rear of the intake not at the front like the stockers....
- (1) large clamp
Car: 1991 FORMULA
stealthram istallation
ok, slow down dude!!! i need to see some pics to understand exactly what needs to be done! i can't comrehend just seeing it in writing!! can you help?
Car: 89 Irocz
Axle/Gears: 342
BG,
Well I got mine like tue, but like everyone else I m waiting for the
fuel rails, their suppose to go out like the 15th. I'm not sure how there going to hook up, but I'll find out when the kit comes. Now all of your sensors and stuff like that, well that shouldn't be too hard, cause you already got the holes drilled and threaded in HSR,
So you just got to relocate them to the new one. The sensor go into different areas, but nearly the same place.It really doesn't like look it would to hard to do if you just take your time. Now the only real thing that look's like a little pain will be the fuel lines. I think that would be the only thing I m not too sure about taking on by myself. But the basic install shouldn't be that hard at all, its just replacing the intake. If you haven't done it before, it may be a prob, but not really hard.
Hey
I havnt heard much about this stealth ram. What is it. How much does it cost and how much HP am I going to get out of it. Do they make ot for the 305 TPI.
http://camaroz28.cardomain.com/id/56424
edit. WILL YOU PLEASE STOP ATTACHING A PIC OF YOUR CAR TO EVERY THREAD YOU POST IN OR I WILL HAVE NO CHOICE BUT TO BLOCK YOU FROM THESE BOARD BECAUSE I AM GETTING SICK AND TIRED OF DELETING YOUR PICS. IF IT IS NOT RELEVANT TO THE THREAD AT HAND, DO NOT POST IT, IF YOU WANT PEOPLE TO SEE YOUR CAR, PUT IT IN THE READER'S RIDES OR AT LEAST IN THE APPEARANCE BOARD. THANK YOU
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
I could be wrong but the stealth ram intake sits considerably higher than the TPI intake. As-is there's little clearance between the tpi intake and the stock trans am hood, and i don't believe a stealth ram would fit in your car. I am assuming you have the stock hood of course. I could be wrong..........
Car: 1989 Iroc-Z
Engine: 350ci SBC
Hey heres and idea! See that little button in the top right hand cornor of the screen that says SEARCH???? HUH??? HUH?? Well USE IT....these questions have been beat to death already!!!!!!!!
Easy guys. Im sure they dont frequent this board as much as you do.
Dont feel bad guys, i got snapped at too. Use the search button and punch in Stealth Ram. You will find pages of all the info you need.
-paul
-paul
Car: 2000 Trans Am
Originally posted by iroc_cragg
Hey
Hey
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
I thought that somebody did put it under a stock Firebird hood, but it required a little "massaging". Let me see if I can find the post.
[Edit]
Here:
This is a quote from this post.
[Edit]
Here:
Originally posted by cfabe
Well, It fits.
It's a tight fit, but it's doable with a stock hood. I just dented in the support on the underside of the hood where it was hitting, and made enough clearance that way. Now, At the moment I have my tranny supported by a jack, not the crossmember, so I might need a little more clearanace, but even with the support dented in as it is now, there's still another 3/8" or so between it and the hood skin, so If i need more I'll just notch out that section of the support and It will have enough room.
The contact points were, as predicted, the two side bolt bulges on the top of the throttle body.
This is using a stock tpi throttle body, btw, in an 82 trans am with the normal hood (no turbo bulge or anything), stock motor mounts.
Well, It fits.
Car: 1991 FORMULA
OK fellas, calm down, no reason to argue. I done know about what mods have to be done to get it to clear the hood, but I'm not worried about it because I have a huge *** ram air hood. and yes I know this question has been done to death a million times, however, not in this way. i'm needing pics of all the hook ups on the stealth ram compared to what they were on a stock tpi. and i really need close ups of all the vacuum connections and fuel line connections. cuz when it comes time for the motor to be put back into the car, i'm going to have to take it to a dealership cuz i don't have a tripod. and you can imagine what kind of bill i will have if they spend a week just fabricating ****. if i already have it done, it would just be a hook up kind of deal. so if there's any way possible, please post some pics of this for me. and as for other people posting...can't we all just get along?
sincerely
badgta
sincerely
badgta
Car: 1991 FORMULA
G0D DA*N where's the pics fella's? i don't mean to be an ******* but i got's to see some close up's of all the hookups!! cmon guy's lets see them!!!!!
badgta,
I highly doubt a dealer service dept would touch a stealth ram install. You could probably find a smaller garage or performance shop to do it for you, but quite honestly, this is so new that no-one is going to have even heard of it before, except for maybe a hardcore performance shop.
Its not a stock installation and there is going to be improvising and fabricating, its part of the territory. I've installed my manifold, but not yet the fuel rail. Here's the stuff that I've ran across thats going to be not stock: The heater hoses and water neck are typical carb-style setup, you might need a new upper rad hose. You'll have to find a water neck that fits. The fuel lines will be -6 AN on the supply and return, I dont know where they are located but I'm guessing in the drivers rear area of the manifold. The stock TPI throttle body bolts on, but you might have to plug a vacuum port on it. There are two tapped vacuum ports on the drivers back of the plenum, looks like 3/8 NPT, you'll have to get hose nipples and re-run all the vacuum line from that. The throttle cables should fit using the bracket from the tpi.
The great thing about the stealth ram is its price. Having someone install it just kills that. It's really not that hard to install, I'd just wait until I had the time and resources to install it myself. That way, you'll know its done right and if theres a problem you'll know where to look.
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
on the pic that Slow89Iroc-Z posted of the stealth ram look at his headers and you see those 4 little metal cable things, what the hell are they? i have the exact headers with the same metal things around them. can you intstall aftermarket headers with those in the way?
Car: 1989 Iroc-Z
Engine: 350ci SBC
92TPIZ28 ok those are not headers those are the stock exhaust manifolds. Those 4 little metal cable things are not cables at all those are the air tubes...... you throw all that stuff out when you put headers on which come with there own air tubes that you attach to the smog pump.......
Engine: 355
Slow89Iroc-Z, thanks for clearing that up for me, i was confused cause my old camaro didn't have them. the stealth ram looks awesome by the way and what were your gains with it? i'm probably going to get one once i get a little more cash so i was wondering how well it's working for you and if you recommend it. thanks
Car: 1991 FORMULA
stealthram installation
g0d d@mn, how did this go from pics of hookups to headers to how much hp it will give you? how about what the subject was? some hookup pics please!!!
here this may help https://www.thirdgen.org/techbb2/sho...hreadid=101299
Car: 1991 FORMULA
test
test...trying to get my signature worked out..sorry for taking up space
Car: 2002 SOM z28
Car: 1991 FORMULA
biochem, buzz off!! don't come on here harping at me when iv'e seen plenty other people in this site with a pic under every post!!! your just jealous that you DON'T have a nice of car as mine so buzz off!! and as far as icon goes, I.COWER.OVER.NOTHING BITCH!! SO BE A MAN AND PUT RACING BEHIND THAT ICON, LOSER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Re: stealthram installation
Originally posted by badgta
biochem, f*ck you!!! don't come on here harping at me when iv'e seen plenty other people in this site with a pic under every post!!! your just jealous that you DON'T have a nice of car as mine so fu*k off!! and as far as icon goes, I.COWER.OVER.NOTHING BITCH!! SO BE A MAN AND PUT RACING BEHIND THAT ICON, LOSER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Car: 1991 FORMULA
i don't mean to be an *******, but there's no excuse for someone coming on here just to be a *****..... i just wanted to get a little help before i jumped in and bought a stealth ram, see above, and have got nothing but morons BASHING ME AND THE DUDES TRYING TO LEND A HAND!!!! as other owners on here you should say something to the one's being a** holes and leave the rest of us out!! and as far as the signiture thing goes, i was working it out ok!!!!! sorry!!!!!! chill!!!!!! forgive me!!, oh btw, i personally don't care what you think of my hood, letalong of my car!!! butt head, if you cant say somthing nice, then shut up!!
Car: `86 SS / `87 SS
It's kinda silly for you to expect a step-by-step on an intake that's NOT HARDLY RELEASED YET, young jackal. Don't fear the new product. Embrace it and install it, and let us know how it goes.
PS, your hood looks like... allergy season is here.
Car: 04 GTO
Transmission: M12 T56
badgta, check your attitude at the door, and also please get rid of the huge picture in your sig, nobody cares what your hood looks like. If i have to manually edit it out myself i will simply block you from this forum, because a.) you have a bad attituude and b.) you expect the most basic of procedures to be spelled out for you. (yes, installing an intake is so easy that if you need pictures, you should probably just not even bother, because when something does go wrong, you will just be screwed.)
Also, you want to rethink the name of your little racing clique. We are still the one and only ICON motorsports, and while we can't discourage biters on other boards, we can keep you from acting like one of us here. You guys are pathetic, i mean, do you think you could have at least tryed not to get pictures of your trailer park in the background of half your images on the site? Bring the racing ROFLMAO...you don't even know how to pinstall an intake and you think you can hang with us. Bwahahahahahahahahahah, try again kids.
9192camaro
16
Feb 3, 2019 12:21 AM
ambainb
Apr 25, 2016 09:21 PM
L98GTA87
Aug 11, 2015 06:55 PM
