Is this a solid start?
Old May 9, 2002 | 04:59 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Not sure if this is the correct place to put this, but here I go...
Ok, I have an '87 305 TPI, and I'm trying to formulate a plan on getting some performance out of her this summer when I start workin. This is what I have so far...
1)Full exhaust, not sure which yet, either full hooker or full MAC
2)AFPR
3)a little ignition upgrading - MSD coil, cap, rotor, and wires
I had bigger plans, but came to this conclusion after I started realizing that I'm not gonna have alotta money to work with. I think I covered the bases fairly well, I've got better flow from the exhaust, more fuel from the AFPR, and a hotter spark from the MSD upgrades. I want your opinion guys, are the small MSD upgrades and AFPR going to add noticeable HP ontop of the full exhaust or am I just wasting my time and hard earned $$$? Can anyone recomend some good upgrades? I'd prefer not to do anything huge like cams, gears, etc etc because when you get into that, I want to do it right, so if you say "you need a better cam" I start thinking new cam, roller rockers, springs, pushrods, etc etc and it adds up...
Anyone?
Old May 9, 2002 | 05:11 PM
5SIZ's Avatar
Car: 1987 IROC-Z
The best mod is a complete and very thorough tune up. then think about upgrading.
Old May 9, 2002 | 05:19 PM
Hg's Avatar
Hg
Car: '87 Z
Yep, already done that...
Got the timing reset when it was at the dealer getting the rear end/differential fluid changed/flushed(had them do it since we dont' have a timing gun nemore), GM wires and coil, new cap, rotor, wiring harness went out and it was changed, took out the fuel pump with it, got a new one from a local Fbody yard, fuel filter, K&N airfilters, mobil 1 supersyn 5W-30, PureONE filter(no more FRAM for me!).
Overall she's running strong, just runs out of breath at 4500rpm, and for some reason doesn't shift till 5500rpm or so....??? 700R4 w/2.73 posi. Not sure what the deal is there... Adjusted the TV cable, helped some but nowhere near alot.
Old May 9, 2002 | 05:22 PM
5SIZ's Avatar
Car: 1987 IROC-Z
STEALTH RAM!
lol, but if you dont have that much, make the car breath...
Old May 9, 2002 | 05:33 PM
Hg's Avatar
Hg
Car: '87 Z
Stealth ram would be a bit much for a 305 I think... then I'd need a new cam... if I got a new cam I'd want roller rockers.... and then it begins. I just can't afford that.
Old May 9, 2002 | 05:58 PM
5SIZ's Avatar
Car: 1987 IROC-Z
Ok then, why don't you port the plenum, get some slp runners, and saiamese the base 2 inches deep? that will help it breath, the base is the most restrictive part in our 305 engine if i'm not mistaken. The exaust you'r planning to get will be good also.
Old May 9, 2002 | 10:49 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd get full exhaust, all Hooker about $525.
Then add a higher stall TC.
I wouldn't bother with the ignition. I would get gears first before TC normally, but seeing you don't have a lot to play with the TC would be easier to install unless you find a whole rear end. Then I'd get one with 3:42s.
Old May 9, 2002 | 11:06 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I think a TC and SLP headers are your best opts. for some noticable gains with out getting too major things or using NOS
Old May 10, 2002 | 01:48 AM
Bort62's Avatar
Do the exhuast, SLP headers and Catback of your Choice.
Then, Look at opening up your Intake as much as you can w/ your die grinder. Siamese the Base If You Want to take it off. Should help Alot.
AFPR is also a good idea, get the Holley.
If You want to do this for real, Get the PROM burning Equipment Now. its under 250$ for the entire setup.
PI TC would be a good ET dropper, but they are pricey )
Gears will also help, But I wouldnt go Deeper than 3.42 W/ the TPI.
Sounds like your on the right track, and have the right attitude. You Will Do well here
Old May 11, 2002 | 03:42 PM
Hg's Avatar
Hg
Car: '87 Z
Bort62: Where can I get "the entire setup" for prom burning from for 250$?
Old May 11, 2002 | 07:34 PM
Bort62's Avatar
See the Sticky Thread at the top of this Forum.
Old May 12, 2002 | 12:08 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
HG, when you get that far save yourself some cash on the AFPR and modify the stock one, there are plenty of posts on how to do it on here, and will cost you less than $5 rather than a $50+ afpr from someone else
Orr89RocZ
Apr 25, 2016 08:28 AM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
Bert87
Aug 23, 2015 03:50 PM
LittleFranks
Aug 20, 2015 03:55 PM
Street Lethal
Aug 13, 2015 08:28 PM
