HUGE throttle body
Old May 18, 2002 | 02:10 PM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
HUGE throttle body
I dont remember where it was that I seen it but it was a stock throttle body that the center divider inside, where the airfoil would normaly go, was cut out so that it was one large oval opening. The person then made a new single peice blade to replace the 2 small circles. They claimed that this would flow about the equivalant to a 65mm throttle body. I picked up a spare throttle body on ebay for $20 and IM thinking about doing this to see what it will do. Anyone have any input on this? Good, bad, otherwise....???
Old May 18, 2002 | 02:58 PM
pontiac's Avatar
excellent
after throttle body coolant bypass, that should be next logical step. i spent too much to buy JET airfoil which was obviously just piece made by blind monkey. that's quality.
anyway, your idea sounds simply good. why not to make some mono blades and port crap out from throttle bodies? good fresh idea!
-P
Old May 18, 2002 | 03:11 PM
88ROC1LE's Avatar
sounds like a good project, I don't have any knowledge of anything like that but I would be interested in what you find out!
Old May 18, 2002 | 03:14 PM
ZZsmpch's Avatar
Sounds good, but looking at a spare I have here, the IAC needs to have the divider in the middle to work. Without it, it looks as if the IAC would be useless.
Old May 18, 2002 | 03:30 PM
rhuarc30's Avatar
I agree, looking at mine, it looks like the divider is part of the function of the IAC. I've seen the monoblade, TPIS makes one, flows like 1800 cfm or something silly like that. You can bore the stock throttle body and make new butterflies for it though. There's been a thread on it, do a search. I think you can go to at least 52MM, maybe a bit more.
Old May 18, 2002 | 03:35 PM
Car: 87 Iroc Z28
Engine: 355 TPI
well when I get my spare TB from ebay I will take a look, might beable to find a way to keep the IAC functioning still with the mono blade, either way IM gonna do something to it to make it bigger, and I will try to take pictures along the way and some notes. Ill keep you guys updated
Old May 18, 2002 | 04:30 PM
Cool Runner's Avatar
Car: 86 Trans Am WS6
Hey the LS1's have a large monoblade so can't we copy their IAC set up or possible adapt an LS1 TB?
I don't know much about the LS1 so this is just food for thought.
Old May 18, 2002 | 06:36 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
no their design pulses a piston to let air by and ours is like a screw that has steps to open up the air flow
Andrew
Old May 19, 2002 | 03:52 AM
Bort62's Avatar
Cause we all know how much your 15 second car's need a 65mm TB>
Old May 19, 2002 | 04:17 AM
age's Avatar
age
Car: 1992 Z28 1LE
hey, come on man... eventhough he might not need one, doesn't mean that we have to knock the guy. I think it's great to see people trying different things.. look at the LT1 intake swap, and siamesing the intake manifold ports.. if you're gonna be sarcastic, then keep it to yourself.
Old May 19, 2002 | 03:57 PM
rhuarc30's Avatar
Agree, if the man can get it to work :hail: if not it's still :hail: for trying. Besides whether or not he need's it, if it works, there will still be a substantial cool factor due to him doing it himself, and having something nobody else has done.
Old May 19, 2002 | 07:08 PM
Car: 87 Iroc Z28
Engine: 355 TPI
yeah, like I said its for a SPARE tb so if it does work, and I do actualy put it on, its just to see what it will do, Im not trying to tell everyone its some mirracle upgrade or anything.
And no offense but my car will pull way better than a 15.
Old May 20, 2002 | 10:36 PM
Swapmaster's Avatar
The stock throttle body flows about 680cfm dry which is about
the same as an 800cfm carburator (wet). This is far more than our
TPI engines can use.
Old May 21, 2002 | 08:19 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I believe arizona speed and marine has a monoblade unit that flows well over 1300 cfm.
Old May 21, 2002 | 08:30 AM
Swapmaster's Avatar
1300cfm will feed two, count them two, 350 engines
spinning at 6,000rpm.
Old May 21, 2002 | 09:00 AM
Jim85IROC's Avatar
Old May 21, 2002 | 09:08 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Or one 350 spinning at 6000 rpm and running 14 lbs of boost...
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
