Any thoughts or Ideas on this setup?
Old Jul 7, 2002 | 02:27 AM
NOSFEDGTA's Avatar
I putting my new motor together I was wondering if anyone has any thoughts or opinions on it.
fresh 355
afr 195's
holley stealth ram "already ordered"
comp cam 224-230 dur@50 530-545 lift with 1.6rr
24lb inj
custom prom.
Any info is great..
Drew
Old Jul 7, 2002 | 04:26 AM
egmonster's Avatar
30lb/hr just to be on the safe side
Old Jul 7, 2002 | 01:04 PM
NOSFEDGTA's Avatar
Ya think it would need more than a 24? I am just curious. I thought if I did the formula right they were good up to about 330-350rwhp...
Drew
Old Jul 7, 2002 | 04:05 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
At the flywheel the 24# are good to 450 hp. The 30# can push 550 hp.
IMO I don't think you'll need the 30. But that just my opinion.
Old Jul 7, 2002 | 04:19 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Yea 24's will be fine. You can also boost fuel pressure to get more flow out of them.
Old Jul 8, 2002 | 11:06 PM
egmonster's Avatar
For me I'd just suggest the bigger injector in case you feel like adding a blower or anything in the future. My personal opinion is that you will be pushing those injectors pretty far and it can't hurt to have bigger ones (seeing as how you're doing a prom tune). Those heads are capable of 500+ hp with an aggressive cam and solid valvetrain. Just my 2 cents.
Old Jul 9, 2002 | 10:40 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Accel makes 26 lb injectors, that way it'll be between the 24 and 30's. You may run too rich with 30lb even with the regulator cranked down to the lowest setting but if you're planning on doing more in the future, than go with the 30lb.
Old Jul 10, 2002 | 12:04 AM
NOSFEDGTA's Avatar
Thanks for the help guys. I am hope this setup puts me in the 12.50 range at about 110mph. It will be an experiment thats for sure. I have not seen a stealth ram setup on a third gen yet and cant wait to see the dyno results. I have only seen and read the magazine articles..
Old Jul 11, 2002 | 10:01 PM
CamaroX84's Avatar
I will be running almost the same setup, except I am using a 230/236 cam with lift of .510/.520 with 1.5 rockers. This cam looks like it matches the upper RPM capabilities of the heads better, but that's just my .02
Old Jul 12, 2002 | 04:45 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I'd get a bigger cam w/ the Stealth Ram, CamaroX84 has the right idea.
BuckeyeROC's Avatar
Double post
Street Lethal
Apr 30, 2019 12:14 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
formula_novice
Aug 18, 2015 08:48 PM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
