Stealth Ram question about the fuel rail.
Old Jul 24, 2002 | 10:22 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Whats up everyone?
I have a question about the Stealth Ram's fuel rail setup. Can the fuel rail be mounted in the opposite position, meaning fuel pressure regulator in front of the throttle body on the passenger side. For the driver's side, the fuel inlet hose will be mounted under the throttle lever. Here's a picture of what Im talking about:
Attached Thumbnails Stealth Ram question about the fuel rail.-rear-shot-hsr.jpg
Old Jul 24, 2002 | 10:23 AM
86Tra/maro's Avatar
Pic #2
Attached Thumbnails Stealth Ram question about the fuel rail.-lower-man.-hsr.jpg
Old Jul 24, 2002 | 10:24 AM
86Tra/maro's Avatar
Pic#3
Attached Thumbnails Stealth Ram question about the fuel rail.-front-shot-hsr.jpg
Old Jul 24, 2002 | 05:23 PM
89ProchargedROC's Avatar
you can move the regulator around if you want, but i'm going to tell you now.....
have fun fitting that inlet fitting on the driver side fuel rail with your throttlebody
Old Jul 24, 2002 | 06:09 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I had the same problem as 89prochargedROC throttle cable guide hit the fitting.I dont know how or If you have heat in your car but I had to use that coolant port under where you have the regulator for the valve for heat.
Old Jul 24, 2002 | 09:14 PM
89Irocz23's Avatar
I dont see it working cause the IAC is proly going to hit the regulator.
Old Jul 25, 2002 | 09:52 PM
MeanYellowZ's Avatar
can I ask a dumb question??
guess its too late huh?
How is it SUPPOSED to be, because thats how I have mine right there.
Old Jul 26, 2002 | 12:40 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
well your suppose to have it the other way around, the cross over in the front, and the reg. on the drivers side. But I did a way like that, I had the cross over in the back, but the block off plug on the driver's front, That way your TB has more than enough to clear. And the reg, on the driver's side, back. And inlet on the pass. front. Basically like his but almost swap around. I got pics at my post. https://www.thirdgen.org/techbb2/sho...hreadid=115008
Old Jul 26, 2002 | 05:26 PM
86Tra/maro's Avatar
Mean Yellow,
Do U mean that U have your car setup just like the one I have pictured & its working with no problems (throttle cable, IAC motor, ETC hitting fuel rail)?
If It can be installed like the picture above why bother with running elbows on the fuel lines & fighting with Fuel lines in the rear of the manifold.
njdaewoo
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
L98GTA87
Aug 11, 2015 06:55 PM
djmarch
Aug 9, 2015 05:27 PM
