I need help with this 52MM throttle body I bought for my lt1 intake..
Old Jul 24, 2002 | 04:40 PM
89Irocz23's Avatar
ok Well I just got in the mail today was gonna bolt it all up. I noticed where is the thing for the IAC..Then read some of the directions and it says you need the OEM collant passage thing. Well my problem is I sold my STOCK TPI stuff about 2 months ago so I dont have that OEM thing. What do I do about this? Where can I find this water passage thing on the bottom of the throttle body and also thats where the IAC goes I believe.
Old Jul 24, 2002 | 04:41 PM
89Irocz23's Avatar
Sorry I forgot its a holley throttle body.
Old Jul 24, 2002 | 07:47 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You indeed need the IAC housing. It's dealer only part. You also ay need the top plate, aftermarket TB's don't come with nothing. Sucks huh? I had almost the same problem.
Old Jul 24, 2002 | 07:50 PM
89Irocz23's Avatar
What do you mean top part? I have the part on top that says holley. Its a metal plate...where do I get these things and how much am I looking at? price wise? Also whats the correct name for them so when I ask for them?
Old Jul 24, 2002 | 08:02 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Just as John said, it's the IAC (Idle Air Control) housing. Its available at your local GM dealer or anybody that handles Delco FI parts.
Old Jul 24, 2002 | 08:15 PM
89Irocz23's Avatar
anyone have a part number in case they give me look
Old Jul 25, 2002 | 05:33 AM
Engine: 4.0L
I just tried to look up the part number in my 1990 Camaro Parts ans illustrations Catalog. Same thing the dealer used.
I have bad news, the part number listed is "N.S." which means not serviced. Translates to you must buy the whole throttle body to get the "IAC Coolant Housing".
Old Jul 25, 2002 | 05:47 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
i got ya hookup
john lingenfelter sells them sepratley for his tb's..... i'm pretty sure they will fit yours.......
Old Jul 25, 2002 | 06:38 AM
Odyssey's Avatar
Or just get a stock TB for 30-40 bucks off Ebay and use that.
Old Jul 25, 2002 | 11:01 AM
89Irocz23's Avatar
where can I buy the john lingenfelter bottom piece? and will it work with my holley throttle body? I would just buy a used piece, but I figured if im gonna spend the moneys I mys well just get a new one. Plus it would look 10x better being new anyway. Another reason is one time I tried to take that piece off my stock throttle body and I broke the head off the torx screws
Old Jul 25, 2002 | 11:05 AM
89Irocz23's Avatar
I looked on year one and found this Accel throttle body accessory kit-Includes IAC motor, coolant cover, clean air cover, and TPS. all that for $259!!!!!!!!!!!!!!!! I just spent $359 on my throttle body...wtf is that just too much? or do I need to buy a used throttle body?
Old Jul 25, 2002 | 09:01 PM
89Irocz23's Avatar
come on guys I need to find this piece cheaper somewhere.
Old Jul 25, 2002 | 10:19 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
chepest way, go to ebay, buy a throttle body, it should be on there, and you'll most likely get it for under $50, definetally under $100
Heres one I found for you....hey what can it hurt, offer the guy a price and see if he will end the auction for you.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1846462112
Old Jul 25, 2002 | 10:21 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
89Irocz23, email me- I should be able to get it to you cheaper than a dealer.
Old Jul 26, 2002 | 07:55 AM
jimbuck's Avatar
You can get that from the dealer. Don't have the price or part number here. I think it was like 35-50 bucks.
Jim Buckingham
Old Jul 27, 2002 | 08:45 PM
jmd's Avatar
jmd
I can get these for the "wholesale" price for anyone else interested.
Old Jul 29, 2002 | 12:49 AM
GhoSSt's Avatar
IAC kit GM 17112127 36.00
Have fun.
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
