Stripped bolt...
Old Dec 15, 2002 | 09:41 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Stripped bolt...
Ok I was going to remove the TPI to acess the damage to my engine but I couldn't get one screw off. I think the head is stripped now so I am stuck. How can I remove the stripped bolt? It's one of the bolts that attach the runners to the plenum.
Old Dec 16, 2002 | 09:46 AM
88TAJeff's Avatar
Car: 88 T/A
If you can get a chisel in there you could loosen the bolt that way... always works for me
Good luck
Old Dec 16, 2002 | 09:37 PM
trans87's Avatar
How do I chisel it out?
Old Dec 17, 2002 | 12:02 AM
88TAJeff's Avatar
Car: 88 T/A
well it only works if you can get a chisel in there (and a hammer of course). If its hiding behind a runner or something then it won't work. Usually you can chisel one side of the bolt and it'll spin.
good luck!
Old Dec 17, 2002 | 12:04 AM
Black88GTA's Avatar
Car: 88 GTA, 94 BMW 840, SVX, Prelude
Engine: 383 w/ Super Ram
Transmission: built 700R4 auto
I had this problem with a valve cover bolt when I was installing my plug wire looms. I tried everything, vise grips clamped so tight I could barely pull them shut, bolt breaker, drilling it, etc. I ended up getting it out by taking the Dremel and a fiberglass cutting wheel, and cutting two sides into the circular head so that there were flat areas on it. Then I got one of those "gator grip" sockets from Home Depot, dropped it on there, and it popped right out. The socket is like $20, but it comes with a 3/8 wrench (which is junk), a socket adapter, and the socket itself. Good luck!
Old Dec 17, 2002 | 03:40 AM
rezinn's Avatar
Wow, a gator grip success story. Neat. I thought that thing looked neat, but was a total gimmick. Oh well. I actually had a similar problem and ended up grinding the side of it and grabbing it with channel locks.
Old Dec 17, 2002 | 01:24 PM
Black88GTA's Avatar
Lol...rezinn, that's what I thought too, but at that point I was ready to try anything. And to my surprise, the thing actually worked really well in that case.
Old Dec 17, 2002 | 09:19 PM
trans87's Avatar
Thanks for the suggestions. I am going to try what rezinn said first since I already have the tools for that and if that doesn't work I will try what Black88GTA said. So rezinn you just ground up the sides of the bolt to make it rough?
Old Dec 18, 2002 | 03:16 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Just get a dremel with a cut-off wheel and drill a slot on the bolt. Then just use a flat-head bit with an impact driver and it should pop out. Hell an impact driver is probably overkill...you could probably get away with a flathead screwdriver.
Old Dec 22, 2002 | 04:49 PM
trans87's Avatar
Well I tried to take the bolt out today since it finally stopped raining. There is a couple problems, where the bolt is located it is hard to get the dremel in and channel locks don't fit at all. I tried using a flathead by grinding a cross section and a torque wrench with a flathead socket but it kept slipping. This bolt is in there tight!! I tried to chisel it out but the chisel just slid everytime I hit it. Any other ideas you guys can think of? This bolt is on the left side (facing the engine) TPI runner bolt.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Amillionoh7
Sep 5, 2015 11:44 PM
