does a SD car have a MAT sensor
Old Mar 24, 2003 | 09:47 PM
BOTTLEDZ28's Avatar
Transmission: A4
Do the speed density cars have a MAT sensor? My TPI air filter snorkel has a sensor in it on the drivers side but nothing is plugged into it. It is notthe orginal snorkel though. Cant I just relocate mine to this hole?
Old Mar 24, 2003 | 10:04 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Yes , they do, I have mine in the plastic intake area too, V6 cars came that way from GM.
Old Mar 24, 2003 | 10:06 PM
BOTTLEDZ28's Avatar
Transmission: A4
so then I most likely have a V6 air snorkel? What did you do, just extend the wires
Old Mar 24, 2003 | 10:11 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Exactly, I just added in the correct length of wire, the computer knows no differant. I am almost certain that only the V6 plastic deals have the boss for the sensor.
Old Mar 25, 2003 | 08:24 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
yup thats there where i put it to, u probably have a v6 dual snorkel, better for u since u dont have to go to the junk yard and hunt for one
Old Mar 25, 2003 | 12:05 PM
5SIZ's Avatar
Car: 1987 IROC-Z
I used to have mine sitting on the winshield LOL. But i put it back into it's rightful home.
Old Mar 25, 2003 | 02:02 PM
BOTTLEDZ28's Avatar
Transmission: A4
so whats so important about using a MAT from a 92 and later GM car?
Old Mar 25, 2003 | 02:08 PM
5SIZ's Avatar
Car: 1987 IROC-Z
the 92 + MAT sensors just work better.
Old Mar 25, 2003 | 02:22 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Relocated MATs are only a good idea if you are in the chip. If you don't adjust the MAT tables to go with the relocation you will end up running way rich in cold weather. V6s and vettes that came with 'relocted' MATs from the factory are calibrated differently than f-bodies.
Old Mar 25, 2003 | 02:23 PM
5SIZ's Avatar
Car: 1987 IROC-Z
and THATS why I put mine back heh.
Old Mar 25, 2003 | 02:31 PM
BOTTLEDZ28's Avatar
Transmission: A4
so then it wouldnt be a good idea then if I am running a Ed Wright stage 2 chip and AFPR set at 45psi. I am putting a HSR in soon. Will the engineactually get more air now. I kinda think it wont since the air stillhas to travel i the same way it does with TPI. And if it does get extra air then a relocated MAT sensor may help equal out the air/fuel ratio. RIght?
Old Mar 25, 2003 | 04:54 PM
Ed Maher's Avatar
Car: 04 GTO
I doubt Ed Wright includes relocated MAT correction with his chips, but thats a question better posed to him.
As for a relocated MAT as a way to trick the ECM. In short, no, thats not how it works. This isn't 1995 anymore, we are way past using ECM trickery to get it to do what we want.
Old Mar 25, 2003 | 06:57 PM
BOTTLEDZ28's Avatar
Transmission: A4
So should I bother then
jaridjohn
Jul 8, 2024 03:49 PM
9192camaro
16
Feb 3, 2019 12:21 AM
lee01
Apr 9, 2016 01:56 PM
squiggy2
Aug 9, 2015 09:30 PM
