pulsator
Old May 4, 2003 | 08:56 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
pulsator
I am in the middle of changing my fuel pump, from what I have read on here I should leave the pulsator out and just replace it with the piece of fuel line that came with my Walbro pump? Does
everyone agree with this?
Old May 4, 2003 | 10:15 PM
ragtop88's Avatar
Car: '88 Camaro ragtop
Engine: 379 destroker
Transmission: m6
Axle/Gears: 10-bolt/3.42
Thats what I did....no problems thus far.
Old May 5, 2003 | 12:04 AM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
Yeah, leave the pulsator out. Use the piece of fuel line that you got. The pulsator is pretty redundant, since there is already a pressure regulator. Besides if the pulsator diaphram ruptures, there goes your fuel pressure and the tank has to come back down. It is just one more thing that can go bad, don't reuse it.
Old May 5, 2003 | 01:37 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Not to mention it doesn't fit quite right & tends to bleed off pressure. Ask me how I know
Old May 5, 2003 | 06:36 PM
Engine: 5.0 TPI
Even GM stopped using pulsators on a vast majority of thier cars since like the 1994 model year. If the factory doesn't istall them half the time...
Old May 5, 2003 | 09:18 PM
NEOMASTERZ28's Avatar
Car: 85 z28
JUST DO WHAT I DID CUT OUT A DOOR IN THE TRUNK UNDER THE RUG AND YOU WILL BE DONE IN 20 MINS HAHAHAH SO EAS Y
Old May 6, 2003 | 05:04 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I would never cut a hole in my GTA. It is not that hard to drop the tank, I had it out in about an hour by myself in the driveway. But, I certainly wish they had made an access door like a lot of other cars with intank pumps.
Old May 6, 2003 | 08:06 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
That's a great way to butcher your car. Do you cut 8 holes in your hood when you change plugs?
Old May 6, 2003 | 08:25 PM
BOTTLEDZ28's Avatar
Transmission: A4
hahahahahaha.
Old Jun 2, 2003 | 06:35 PM
Car: 85 z28
HAHAHAH i made a door and got done in 20 mins. so what if i cut in to you wont even know unless u see it or tell u. sorry some people dont have time to drop the rear and the tank a$$ hole
Old Jun 2, 2003 | 06:38 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
No, because they are easily accessible.
Old Jun 2, 2003 | 09:14 PM
Jim85IROC's Avatar
So is the fuel pump. You just need to take a little initiative, or go buy a celica. They already have an access panel in the interior.
Old Jun 2, 2003 | 10:41 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
I took the initiative.
I now have a nice riveted/hinged access panel for my fuel pump.
Looks OE.
Biggwinn
Jun 1, 2006 07:25 PM
dyeager535
May 15, 2004 09:44 PM
Xophertony
Nov 29, 2003 08:28 PM
ChevyLuva3
Mar 10, 2002 07:28 PM
2QUIK6
Jan 23, 2001 04:01 PM
